Sponsors    Home    Forums  Hop To Forum Categories  General Blending Discussion    Spirits of Turpentine
is this the same as paint thinner?
Bernie
1983 Mercedes 300SD
1995 Jetta GL
Location: between a rock and a hard place | Registered: 22 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Turpentine (also called spirit of turpentine, oil of turpentine, wood turpentine, gum turpentine) is a fluid obtained by the distillation of resin obtained from trees, mainly pine trees. Yes, turpentine is a "paint thinner" however that term is generally used to describe a variety of products made from petroleum. Read the labels to be sure.
'89 Toyota 3.4L TDI + FPHE
BD+ULSD+VO+JetB blends
thanks John
Bernie
1983 Mercedes 300SD
1995 Jetta GL
