I cold filter as SOP because the temperature can get below 60°F for at least half the year. Below that temperature PHO and fats [and biodiesel made from them] can precipitate out and clog fuel systems. The cold filtering process I use separates the PHO and fats before the fuel goes into the tank, which eliminates clogging problems. I use a similar process for biodiesel as well.
--.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
I always cold filter,even with wmo/watf mix.
Can you explain how you do the cold filtering?
Try these links. I do mine exactly the way John Galt describes.
http://biodiesel.infopop.cc/ev...1014871/m/8311073932 1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
I am in So Fl and I heat my oil before I filter down thru 25/10/1 micron bag filters. I mix diesel or Kero depending the time of the year and still wind up plugging up my primary with fat. In the winter HA I mix more diesel into my wvo depending on the temp. I run up to Jax every weekend and it will get real cold up there, at least for me. I will then just dump a load of diesel into the 300 and have no problem.
I usally buy my oil for spring summer,an fall, in the winter.When its below 30 degrees in daytime,I filter oil thru old levi jeans.Pants legs tied,wire hoop to hold pants open). You will be surprised how much fat is in the oil.Pretty much after filtering this way my oil will flow in the teens. 126 diesels yahoo groups 83 SD straight exhaust 94 Cobra Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost 0-60 10.8, 37 mpg highest 2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer. |
