Sponsors    Home    Forums  Hop To Forum Categories  General Blending Discussion    The Best Blend for Diesel Engine Fuel
Page 1 ... 4 5 6 7 8 9 10 12
more good info, thanks John
I have some related data from the other sources, so I built a spreadsheet that details and compares it all, good useful data
thanks
Mark
Location: Vacaville,CA(northern CA) | Registered: 31 January 2008Reply With QuoteEdit or Delete MessageReport This Post
how are you guys *physically* 'blending'?
I mean, when you add all these ingredients to a 55 gal drum, or whatever, how are you MIXING it up?
no spark, right?
so drill w/ a paint paddle is out?
so what to use? and HOW LONG do you mix it for? at what speeds?
thanks
rOLf
2 yrs and 100k mi on WVO - '93 VW EuroVan 2-tank w/ tank heat/HOH/10-micron heated Fleetguard, FPHE
Location: NE USA | Registered: 09 April 2005Reply With QuoteEdit or Delete MessageReport This Post
I run a small 2-3 GPM pump [MD-10] to circulate the mix from near the bottom to the top of the barrel for an hour or so.
http://www.iwakiamerica.com/products/wmd.htm
The same pump is handy for general process transfer, it produces no sparks, and there are no seals to leak.
'89 Toyota 3.4L TDI + FPHE
BD+ULSD+VO+JetB blends
Here is My blend mixing and fueling station
John,
You really mix for an hour?
Why?
No flame here just wondering if I need to mix longer.
I mix 5 min tops by sloshing a 15 gal barrel 1/2 full-ish
C.
C.
Pump and Heater controllers are a must have. (ask Tilly why) Find a "Free" timer plan here: www.biofuelcontrols.com Please sign guestbook and let me know what you think
1983 - Mercedes 300SD
I found it more difficult to slosh a full 200 litre drum. The pump ensures complete mixing of the 50-50 VO-ULSD.
So, not a reaction issue more of a volume thing. See, I still have bio-d thoughts running through my head.
The Benz seems to be in constant need of fiddling. So I have turned my attention to the Libby. But, killing a $25K car is harder to take than killing a $400 car. The fuel pump on the Libby is gear driven and could suck a golf ball through a garden hose. My worry is the common rail and "cold" wvo blend. So far in limited tests, she runs and starts OK.
C.
so
I have read through a bunch of these threads and am gathering that up to 30% RUG would probably be OK in my 81 Rabbit
thinking about a VERY simple baseline blend of 75% WVO and 25% RUG
nothing else
unheated, unmodified
any thoughts on that?
thanks
rOLf
The guy "oil crusher" uses sunflower oil from his crops & crushing them for oil. He uses a hydrometer to try & get the same viscosity of dino. He didn't know about used fry oil but he said he thins his oil quite abit. I'm going to look into getting one of these hydrometers, & thin out my blend more with rug & see how it works. He gave me the specs for the meter. I thought he was using a battery tester. NOT.
99 E350 psd
Location: central, east coast FL | Registered: 04 September 2005Reply With QuoteEdit or Delete MessageReport This Post
yeah, but hydrometer doesn't measure viscosity, it measures specific gravity
I actually bought one based on his postings, but to get viscosity to match you'd actually need to use a viscometer
rOLf
I wondering the same thing. I was trying to justify, in thinking the thicker the liquid, the hydrometer bulb would have a greater effort to displace liquid.(sink) Maybe I'll just stick to my timed, hole dripper.
99 E350 psd
Originally posted by EuDeMan:
so
nothing else
thanks
sure if volkswagon states that you can use up to 30% regular gasoiline then it should be safe to use, just make sure that you use regular gasoline (lower octane is better)
since veg oil is more lubricant than diesel it shouldn´t be a problem to use more than 30% but its´s pointless to gamble
I will do the same as you, use 20-25% RUG Wink
greets
_________________________
vw golf-92 mkII ECOdiesel whopping 60hp and 5,4Litres/100km(43,5 USmpg)
"wvo blending"Wink
1part diesel 2part wvo
Location: blekinge/scania | Registered: 29 February 2008Reply With QuoteEdit or Delete MessageReport This Post
not to much RUG, the octane makes the engine shutter, I would not use more than 10% Fresh RUG, if you can find a source of stale RUG that would be better, if not K-1 is much better and add a good cetane boost, Happy veggin'
1985 300SD 290K no mods, his 20K on veg(since October 05)
01 Jetta TDI 179K stock, hers (ours)35K on veg(since august 06)
99 Suburban 6.5L 252K stock, 0 K on veg(since sept 08),75% WVO, 15% stale RUG, AMSOIL cetane boost, AMSOIL diesel fuel modifier, acetone, startron, pure gum turpentine
Location: Uncasville, CT | Registered: 15 July 2006Reply With QuoteEdit or Delete MessageReport This Post
but kero is $5/gal, RUG is $3/gal (!)
any other choices? (I agree, K1 is a nice fuel - but EXPENSIVE around here)
anyone tried blending E85/WVO?? percentages?
veggedout: would you mind posting the percentages of your various additives, WHY you use them, and WHERE you get them? thanks VERY much
rOLf
use find function for "stove oil"
e85 doesn´t work any good in diesels not with wvo or svo it does´t even mix with diesel(it seperates almost imediately), to much octane, to hard to ignite... and so on and so fourth
gasoline works good even blended with regular diesel new fresh 20% regular gasoline 80% ULSD(the one diesel with lowest lubrication) works in the winter, inj-pump have been checked without any damage
"wvo blending"Wink
for the winter I mix 30% stale RUG to 70% soybean WVO, I then add to that mix 1 oz to five gal of the following, AMSOIL cetane boost, diesel fuel modifier, and cold flow improver, I add 1 oz startron to 32 gal, 1 oz acetone to 10 gal and 1 oz pure gum turpentine to 1 gal = @.50 a gal total cost, I order the AMSOIL products straight from AMSOIL by the case to save on shipping useing this number 1255918, they help to increase cetane, improve cold flow properties, and keep the tank, filters and injectors clean. I add the startron to helpkeep the fuel free of growing things, I get it at the local boat yard, I also get the stale RUG at the local boat yard for free, i get the acetone at walmart and add it to help keep fats in suspention, and last I get the pure gum turp at ace true value and add it to increase the cetane some more and give the car a little extra kick, it also help thin the oil, I know this seems like a lot but I want to keep my cars running for as long as possible and since it's only costing me @ .50 a gal, I think it's well worth the little bit of extra, even if others think it's over kill, my cars run great and have had no fuel related problems since useing this fuel, I now also take this mix and put 4 gal in a five gal jug, add a gal of K-1 and mix well, then add to house, for month now, no problems, runs the same and have checked the flu while running and see no, I mean NO smoke at all, HTH and happy veggin'
thanks veggedout, very useful info
did you make this up ourself, or get these ideas from other people/places? (just curious)
thanks again
rOLf
calling local boatyards for stale RUG
no luck so far, but a guys offered me 20 gal of sugar-contaminated RUG (divorce fallout - he/she got POed and emptied a 5 lb bag of sugar into the tank)
any idea if I could remove the sugar somehow? water wash? or would this be better candidate to run through the boiler?
thanks
rOLf
some on my own and some from reading and asking lots of questions, as for the sweet gas, I think the disolved sugar should weigh much more than the gas and sink to the bottom, so if you took just the top 2/3 you should be alright, keep calling or even better, I find to talk to someone in person and use the word recycle, that smoetimes can sprark some intrest, good luck and happy veggin', by the way, you got that van back on the road yet?
  Powered by Eve Community Page 1 ... 4 5 6 7 8 9 10 12
