This list includes the most common materials used for diesel fuel.
If you were to blend your best mix how much of each of the following [or others] would you use? In what engine? ________________ Down to what "clean start-up" temperature? _________________ Petro diesel Kerosene Jet fuel Stove Oil Gasoline, petrol Paint thinner, Varsol, Mineral spirits ATF transmission fluid Transformer oil Engine oil Used engine oil Machine oil Biodiesel Canola oil Soy oil Hydrogenated oil WierdVegOil of unknown origin Acetone Ethanol Methanol Naptha Toluene Turpentine Xylene This message has been edited. Last edited by: john galt, --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- |
70% WVO 30% Stale RUG (Amsoil Diesel fuel modifier, Amsoil cetane boost, Amsoil cold flow improver) 1oz to five gal, acetone 1oz to 10 gal, Down to -5F in 2001 jetta TDI and 1985 300 SD MB
1985 300SD 290K no mods, his 20K on veg(since October 05) 01 Jetta TDI 179K stock, hers (ours)35K on veg(since august 06) 99 Suburban 6.5L 252K stock, 0 K on veg(since sept 08),75% WVO, 15% stale RUG, AMSOIL cetane boost, AMSOIL diesel fuel modifier, acetone, startron, pure gum turpentine |
I use 75% wvo, 20% kerosene, 5% rug. Temps here don't get much below 58 degrees in the evenings.
I'm still cautious, running 50% my blend with 50% diesel. I have two vehicles I'm running this in a 2002 Huyudai 2.5 diesel and a Nissan Frontier 3.0 turbo. |
Mercedes 300 D: 10 gallons vegetable oil, 1 gallons kerosene, 0.5 gallons RUG, 7 ounces diesel clean, 1 ounce Deezol, 4 ml Kathon FP 1.5 aviation. In winter, down to 15 degrees F, add 1.5 gallons kerosene.
For volkswagen jetta, add 1.5 gallons kerosene in summer, 2 gallons in winter (down to 15 F), otherwise same formula. Jetta definitely harder to start in winter. |
mine too, try pumping it after 2 cycles of the glow plugs, should start right up!
Winter: 20% RUG/ WVO unheated fuel system down to 0C
40% Biodiesel, 10% Rug WVO heated fuel system to 0C Summer: 5-10% Rug WVO to 40C heated or not 10-20% Biodiesel WVO Heated system to 40C '78 300D **** * 1978 Merc 300D. Running Blend and 2 tank system with Home Made HE and water injection. |
I believe he means that his overall mix is 50% diesel & the other 50% makeup is his Blend. Why are you cautious? Is it maybe because you have a relatively newer type of DI & TDI diesel? I would not want to run any type of experimental fuel on the current ULSD models. From what I've read, these are only to run on ULSD. Or is that just propaganda? From one of the postings here, the best additive for lubricity is soy oil 98 Dodge 24V 5.9 Turbo Kubota small farm tractor Heating house with a Wood Doctor outdoor woodburning furnace |
Sorry I didn't get back sooner, but the mix in the truck is 50% diesel and 50% blend which works out to be 50% diesel, 38% wvo, 10% kero, & 2%rug.
Recently I've bumped the mixture up to approx 75% blend in the tank with 25% diesel. It gets a little hard starting in the morning because the ambient temp gets down to around 55 degrees overnight. After it initially starting and running for a short period, the Nissan starts up without problems and runs fine. I'm playing around with one of those glow plugs mounted in a base for changing the location of an oil filter. Currently it is the first filter in line from the tank. I'll be moving the hoses so the heated output wil go directly to the injection pump. As soon as I have tried this I'll post my findings. I'm cautious because I'm new at this and am still learning. |
try adding some cetane boost to your mix, that will help it start a little better!
Thanks. I'll get some and give it a try. |
So far, I've changed the blend down to 70% wvo, 25% diesel, & 5% rug. This is the latest batch. I would have used kerosene at 25 %, but there wasn't any when I went to buy it. So I substituted the diesel in the blend. Hopefully the next batch will be back to kerosene. Not too happy with the glow plug in the filter trick at the moment. The filter I found here that would fit the base was a PH8 and that holds a lot of fuel as opposed to a PH16. I am seriously considering going back to 50% blend and 50% diesel for the Nissan. Finding cetane booster here is not too easy. I'd love to try some AMSOIL if I could get my hands on it. |
Go on their website and go to the find a dealer near you, if none, it would probibly no be worth it unless you buy a case (shipping) doesn't cost that much more to ship a case than a bottle! K-1 will work much better than D-2 for thinning!
I HAVE A 2003 DODGE CUMMINGS I USE A 23%RUG TO 77%WVO.DOES ANYBODY KNOW WHAT % TO USE IN THE WINTER TIME 32%. WHAT%OF RUG. THANKS ART
your brave, I would never use more than 10% fresh RUG,just too much octane
the temp is 35f what is the best mix.what is stale rug.
stale RUG is just old stale gas I get from the local boat yard for free, it has lost all or most of its octane, if 35F is the coldest it's going to get you should be fine with 25% thinner as well as an anti jell or cold flow improver as well as a cetane boost for easyier starting and smoother running engine
thanks for the info veggedout. i was afraid of using 25%rug but i know someone that has been using it for 3yrs so i am going to take my chances because kero is $4 a gal here in tx. and rug is $2.89 thank, art
| Previous Topic | Next Topic | Powered by Eve For Enterprise | Page 1 2 3 4 ... 12 |
