I just checked Kerosene its time was 15.1 seconds. A little thinner than diesel but not as thin as RUG.
Right now my thoughts are to use injector heaters with the blend and coolant heated fuel filter. I considered an electric inline heater so the fuel would be warm upon reaching the IP until the engine comes up to temperature. I read a post one mans theory elsewhere, he believes the hot oil hitting the cold GM rotary IP causes the rotary shaft to expand due to the heat faster than the cold body and causes problems. This makes sense but just wondering if what others are doing with WVO blends in their 6.2/6.5 engines? I am not worried about my fuel pump, I installed a Carter and am sure it will handle the increased thickness (up to a point) but not sure if I should add the inline electric heater or not. 15-20% thicker doesn't seem like that much if that is all we are talking. |
| Powered by Eve Community | Page 1 2 3 4 5 |
