This is what im doing but only im useing wsvo.cleaning it down to 1 micron.the viscosity is the key.
http://www.oilcrusher.5u.com/ |
StrikerDiesel, checked out your website, I am impressed. I too wish I could do that but as long as I can find WVO it seems easier. You mentioned you blend with RUG, what percentage?
Rusty |
I like the more power aspect! harrr-arrrr-arrr
99 E350 psd |
Down here in Panama I was able to get my Nissan Frontier to go 50% diesel- 50% blend. The blend I have settled on so far is 75%wvo, 25% kerosene, 5% rug (no known source for stale rug), & 2 oz of acetone to ever 10 gallons of blend (Thanks, Veggedout!). Not sure what the acetone actually does, but my Nissan is running pretty well with it. Unfortunately cetane boost is a little pricey and have yet to find a way to get Amesoil products at a good price. No one knows if turpentine exists here.
My 2002 Hyundai Galloper with a 2.5 liter loves the stuf and I'm running 100% blend in it. Happy New year to all |
billbaio, I think you have a 105% mix? also I olny use 1 oz acetone to 10 gal, but I think john uses 2 oz and some use even more, as long as it works for you, that's great
1985 300SD 290K no mods, his 20K on veg(since October 05) 01 Jetta TDI 179K stock, hers (ours)35K on veg(since august 06) 99 Suburban 6.5L 252K stock, 0 K on veg(since sept 08),75% WVO, 15% stale RUG, AMSOIL cetane boost, AMSOIL diesel fuel modifier, acetone, startron, pure gum turpentine |
I started using the 50/50 mix when I drove the van on a 500+ mile trip. The blend worked wonderful for the trip, but when I got back the weather got cold. I tried to start the van after it had sat for a week, and it would not start. I found out that the mix had seperated, and it was trying to start on VO. I installed a good fuel pump (pusher) before the primary filter, and it starts now. I think the blend would work fine during the summer, but I am going to run just Dino until it gets warmer. I would like to try a blend of VO & RUG, but I am afraid it might seperate as well. Does anyone know which fuel has the least chance of seperating from VO- RUG or Dino? 1980 AMC Eagle Wagon 3.6L VM Turbodiesel (one of 2 known to exist) 4 WVO Benzs: 1980 300SD, 1982 300CD, 1983 300D, 1985 190D 1983 GMC Van 6.2 Diesel |
What's referred to here as fuel separation, is most likely the high melt point trans-fats and hydrogenated oil dropping out of solution as they solidify. It's a common problem when these fats are not separated out with the processing of the oil. The VO fuel that does not separate has the fats and h-oil removed and is mixed with #1 winter diesel not #2 summer diesel.
--.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
The oil I used was new NON Hydrogenated Soybean oil. I am going to try an experiment with mixing different blends, and placing them outside overnight. Maybe I can get a better idea of what will settle or not. 1980 AMC Eagle Wagon 3.6L VM Turbodiesel (one of 2 known to exist) 4 WVO Benzs: 1980 300SD, 1982 300CD, 1983 300D, 1985 190D 1983 GMC Van 6.2 Diesel |
ok folks
Im having my first prob. in my 06 cummings lost power down to 50mph for about three miles. engine rpm would rev but i could not get any more speed. engine light came on and is still on but power has been restored and running great. i just had fuel filter replaced last week with the oil change. any ideas? having truck looked at this friday at the dealership 2006 Dodge 2500 run on 50/50 of petro diesel and blend. |
my blend is 20 filtered wvo 2 gal kero, i gal rug and 12 oz diesel clean with cetain boost, fuel tank is filled with 15 gal mix and 17 gal dino.
Don't tell dealership of the blend. They will blame the blend w/out seriously trying to diagnose. Sounds to me like you got an air leak. Maybe one of the lines on the fuel filter that just got installed? Maybe they left off the ruber that goes on the fuel filter so it is sucking air now?? PS- Start a new thread since this is way off topic now. _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. |
Nothing, it is off-spec new oil. 1980 AMC Eagle Wagon 3.6L VM Turbodiesel (one of 2 known to exist) 4 WVO Benzs: 1980 300SD, 1982 300CD, 1983 300D, 1985 190D 1983 GMC Van 6.2 Diesel |
Whatever is available around here (So. Cal.). I think it is #2. 1980 AMC Eagle Wagon 3.6L VM Turbodiesel (one of 2 known to exist) 4 WVO Benzs: 1980 300SD, 1982 300CD, 1983 300D, 1985 190D 1983 GMC Van 6.2 Diesel |
It's been reported that some diesel is saturated with so much paraffin wax to increase the BTUs, that the veg-oil can't fully dissolve, and with even a slight drop in temperature separation occurs. Diluting the oil with stale gasoline, stove oil, jet fuel, or kerosene, before mixing it with diesel, usually solves the separation problem.
Hey guys. I'm hoping someone out there can give me a few pointers on a reasonably safe blend for a Ford 6.0 that won't require any heaters. Veggeout's blend looks interesting. Any opinions on how it might work for me. I'm new to all this so please excuse my lack of knowledge. I'm trying to learn all I can. Thanks
answer here:
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9751014871/m/8221090622/p/1 --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
This site has been a great help.Being new here I don't know what these terms mean please help.
Rug and dino I'm having problems with my WVO its too thick. |
Disregard that last post I found what I was looking for(don't want to get yelled at) LOL
no problem, it's kind of like starting a new job with all kinds of new lingo, it takes a little while to figure it all out, we'll help all we can, Happy veggin'
| Powered by Eve Community | Page 1 2 3 4 5 |
