Sponsors    Home    Forums  Hop To Forum Categories  General Blending Discussion    umo blends?
Has anyone used UMO blends? What was your blend percentage if you have? And has anyone blended in the 99 PSD?
Location: ga | Registered: 17 July 2008Reply With QuoteEdit or Delete MessageReport This Post
Yes search on WMO for 89 posts, or see these threads:
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/97510148...791049152#9791049152
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9751014871/m/1261092442
I always never go over 50% wmo in seperate tank with heaters on,and in loop so I don't blacken my diesel tank.
126 diesels yahoo groups
83 SD straight exhaust 94 Cobra
Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost
0-60 10.8, 37 mpg highest
2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer.
at what percentage WMO does your 617 begin to smoke?
80's NA VWs & NA and turbo Benzes, '91 E350 7.3 IDI NA
various bicycles with trailers and gearing low enough to ride up a cliff ;-)
Location: Pacific Southwest, USA | Registered: 28 April 2006Reply With QuoteEdit or Delete MessageReport This Post
At 25% it stinks,but no real smoke even at 50%.I've learned something about turpentine,added to the mixture to stop coking,and smoke.I will in the summer months have more info. One thing over wmo to wvo,you can use main tank,where wvo coats the tank with stuff.I still run heaters with wmo,and rinse cylinders before shut down with 6 gal diesel tank.
Ok now if you blend 2 gals of wvo to 10 gals. wmo,it stops the stinky oil smell.All you will smell is food.Now I blend wvo,and wmo with 50% diesel,then cold filter.Best at below freezing.It removes and traces of water(turned to ice).
Now that I have a good source for WVO,my waste motor,and trans oil,will be used to add with Home Heating Oil.50% blend with heated fuel lines to heater.
will39 here i have blended now for 3 years winter blend 100 lts wvo 10lts kero 5lts ulp if it drops below freezing i ad 5lts diesel the colder it gets a little more diesel i have heaters in my heater hose line .i setle my oil in 1000 ltr tanks for 6 monthes then put through 5 micron bag filter when i fill truck it goes through a enclosed filter of 3 microns into tank i have no trouble at all temp down to 5 below cel my ute sits in car port all night and starts good dont change fillters very often but carry spare christchurch new zealand
Location: Christchurch, new zealandhave | Registered: 14 August 2008Reply With QuoteEdit or Delete MessageReport This Post
I tried recently mixing 10% UMO into my WVO. I mixed well, heated to dewater (which stirs it more), and let settle for 3 weeks. After settling, what I pumped off smelled like motor oil a little, but was as clear as fresh VO. Not a trace of the black from the UMO! I guess all that dropped out.
WMO and wvo won't mix,I tried even with gas.
DCS
I don't know what sort of WMO and WVO you were using but they certainly mix very well and don't separate in my experience!
1978 Merc 300D.
mine didn't,maybe because mine is wvo is peanut oil.
I had these blends sitting around for 6-8 months
After about 8 or 9 months I burned them in my stove. The only fallout was a lil fat.Here's the orig post http://biodiesel.infopop.cc/ev...931095252#2931095252
Stu
Registered: 28 March 2008Reply With QuoteEdit or Delete MessageReport This Post
