Rusty, The stock fuel filter on your car is 5 micron, and I think that is an absolute, not a nominal rating. Whether you want to replace it or not depends on how meticulous you are with your WVO. If you do replace it, do try and keep the cigar shaped return line. I have NO idea why M-B engineered this way, and it runs fine w/o, but every merc mech I know yells at me to not use straight line. ?. Something about the pulsing of the flow? On my older 123 chassis I have removed the stock main fuel filter and replaced it with a (coolant lines and mild electric heat exchange) heated DavcoTec 234a. This also includes a water trap which I don't think your car has. You might consider adding one, lotsa older Merc owners do. I like the Davco becasue the filter elements come in 2 and 3 micron ratings. They are not a kit making company. They make products for diesel fleets. Very reliable and excellent customer service. You might also consider adding another in-line pre-filter or two - the see thru ones. I like to have one right before the IP, one right after the send line and one right before the return line. I am a big fan of see-thru options! This lets me evaluate all points of the flow. I once solved an extremely troublesome backpressure problem on a heated twin tank system with a looped return ONLY because I had see thru lines to troubleshoot with (and some foreceps to crimp lines). No matter what the owner did, VO would pour back into the diesel AND the other way around In those kinds of temps, see how long it takes to cold start on ULSD and note the exhaust. Use that as a baseline to evaluate your blends. I was just travelling in similar temps and decided to add 10% RUG to my 75%SVO tank/25% and see if it made a difference on starts, performance or efficiency and I didn't notice much of any difference except that the gas mileage went down over a couple hundred miles of highway travelling. I have worked on your vintage model for folks WVO fueling and have never seen a problem with fuel pumps. The IP, as you know, is a very robust Bosch (Did you know they are the world's largest NPO!) product. I have installed a lift pump with my Davco Tec, nothing special and I have never bothered checking the actual effective pressure on my ride. Especially if you are blending and not using heat, gravity should do all the work for you. Just make sure the tank and fuel system is properly ventillated and the filters regularly changed. I use compressed air to blow out the hard lines, send return and vent. You might also try posting your Merc specific questions to the biodiesel.infopop forum over here: Diesel Vehicles and other equipment: Mercedes There is also this great Merc resource: http://www.mercedes.cx/archives/ And I also like this mailing list: mercedes@mercedesmailinglist.com But I find that the Mercedes Benz Club of America and their forum http://mbca.cartama.net is second only to talking to the mechanics at the dealership or independant, certified shops. For your '94, I wouldn't bother taking it to anyone born after 1974. The 35+ mechanic crowd will likely get you someone who may have actually worked on these cars when they were first introduced. Possibly even fell in love with them Good Luck!
Jeffrey might take this as further proof of my "fillibustering" against RUG blenders (LoL!! I have a small 12V lift pump installed just prior to the Davco in the engine compartment (on the drivers wheel well). I have seen some people install these right where the tank send line is in the back, under the car. Aloha! |
Rusty,
If I recall correctly, you said the car has recently been serviced. I forget, does your 6 have mechanical or hydraulic valve lifters? Either way, if the clearances are within spec and the fluids and filters have been attended to, I would check the tire pressure and start with a coast down test to determine your current maximum POTENTIAL efficiency (miles per gallon) Check out: http://unwiredtools.com/utcoastdown.asp and take your ride to a weigh station to get it weighed. The weight and the average of 70-60 coast down times will help you determine the max fuel efficieny of your car. Now, test the ACTUAL m.p.g. How far off are they? IF the POTENTIAL m.p.g. is really far off from either: 1) the manufacturers estimates for the E.P.A. or 2) your ACTUAL m.p.g. then you will want to start troubleshooting. I would start with the wheel bearrings, brakes,alignment and toe-in. All this will give you a good baseline and help you to evaluate thecondition of the car before you start adding the variables of unregulated fuels. Once you've done this, get an idea of your performance and note you 0-62 times on a straightaway and evaluate how that performance test changes with your fuel blends. Lastly, make a mental note of how long it takes to turn the engine over in the cold on ULSD first. Also note the emissions. By the time the weather warms up you will be in a great position to make educated decisions about what will work best for you. I look forward to hearing about your successes Aloha! FROM: http://unwiredtools.com/utcoastdown.asp "Coast Down Power Test This tool calculates the amount of power needed to move a car at a steady speed as measured in MPG. This tool is useful for measuring the total power load and thus MPG capability of the car. Power produced by the engine is used for/consumed by: 1. Accelerating 2. Going up hills 3. Aerodynamic drag 4. Overcoming mechanical friction including: * Drag due to toe-in. (Learn more about toe-in) * Wheel bearings * Tire rolling friction * Brake drag (if any) * Drivetrain friction Many cars are capable of getting far better MPG! This tool is intended to help identify problems which cause excessive drag and friction. This tool uses a measurement of how long it takes to coast from 70 mph to 60mph. This duration (in seconds) is used to calculate the total power consumed by aerodynamic drag and mechanical friction. Here's how to perform the test: 1. Find a level strech of highway. 2. Accelerate to just above 70 mph then put the transmission in neutral. 3. Time how long it takes for the speed to decrease from 70 mph to 60 mph. 4. Repeat the test in the opposite direction and average the results. This will serve to cancel out any effects due to wind or slope. [the integers entered are hypothetical] Weight of the car, including the driver and any passengers (lbs) 3595 Starting Velocity : Vstart (mph) 70 Ending Velocity : Vend (mph) 60 Time to get from Vstart to Vend (seconds) 12 Horse Power consumed by your car is 23.652 Miles Per Gallon = 30.739" Note, the test presumes that you have attended to any mechanical or fuel delivery issues first. |
Replace the engine.
The engine was just rebuilt, I know all the history with this engine and I find it hard to believe it could be as bad as everyone says. I spoke with a Mercedes mechanic (actually from Germany) who used to own a 350 in a sedan, he said not to believe everything you hear about them. Most people can get over 100,000 miles with them which gives me alot of time to figure out what to do.
Rusty |
The rodbender OM603 in my 350SDL lasted 240K. When it died I dropped in a 3.0L OM603. Same engine with a slightly smaller displacement. Not that hard to find a 3.0L version and you can rebuild it yourself if so inclined. You will loose a small amount of low end grunt with the 3.0 over the 3.5 but it more than makes up for it when the turbo spools up.
Everything from your 3.5 will bolt onto the 3.0 so no need to scrounge odd bits and pieces. Best thing to do is find a short block 3.0 and put your newer head from the 3.5 on it. Anyway, U have lots of options if it ever pukes a rod. HTH, Shane Lowrance '97 E350 PSD over 30K on blend '74 Bronco with a Cummins 4bt. 10K on the blend in this one '91 350SDL Benz 10K on the blend in this one My blend: 81%WVO, 17.5% K1, .5% Acetone, 1% Turpentine, a shot of Diesel Kleen per bottle specs. Oil is dewatered and filtered down to 5 micron. Thinners mixed in and final filter is 1 micron from storage to the vehicle tank. |
