Sounds normal, the thicker blend causes a higher pressure drop across the filter at higher flow rates. Could be a bad thing if the filter light is indicating low lift pump pressure to your injection pump input, depends on what makes the filter light come on, I don't know the details for your vehicle so hopefully others will know what controls the filter light. Reducing the amount of veg in the blend would likely keep the light from coming on. A friend here has the same problem with his 93 Ford 7.3L IDI pickup, the filter light flickers every now and then when the weather is cool, he ignores the light?
Mix with kerosene.
Right now I run 50/50 with heaters,diesel/wvo.Cool morning here.August will be back to 70/30.
I always blend in diesel that way I need no heated fuel pickup,and easier to pump fuel in car. 126 diesels yahoo groups 83 SD straight exhaust 94 Cobra Cold air,real cold.Cobra electric radiator fan,Monark nozzles,5 psi electric fuel pump.85 amp alternator 12" subs.26 psi boost 0-60 10.8, 37 mpg highest 2 tank,wvo,boost guage ,line heaters,coolant heater Fattywagons customer. |
I'll second UFO's comment. Kerosene is great for blending. You can't let a little issue like road taxes stop you. It's a pain having to pump into a container then into the vehicle, but it really blends well and has better cold weather properties than ULSD.
"mixing up a bunch of magic stuff" Al 2005 Jeep Liberty CRD - B100 2005 Ford F250 6.0 -B100 Kubota BX 2300 - B100 Lopi Republic 1250 - Glycerol/Sawdust Logs |
Here in TN its over $3.00 a gal.
Ya, that's the only issue with K1. Here right now it's about the same as ULSD, but who know's how long that will last.
Drive less than 75 mph. Seriously, is the speed limit really 75 there?
Add about 5% K1 and compare, or lower your speed a little and compare. Continue to learn the tolerance of your truck and decide on the trade off you are willing to accept. I have run 100% vo for the last several months. I rarely drive above 60. David Norwood 2001 F350 7.3 DI purchased new by me and i believe it is the first DI Ford experimented with and talked about on this forum. The single OEM fuel tank only. Updated 1/2009 . HOH for fuel line heat from tank to 12v lift pump. GPI/CIM-TEK spin on filterhead and 10 micron filter. Two 12v 36" heaters wrapped around metal fuel lines. One before add on filter and one before OEM filter.dttk44@bellsouth.net Cool weather mixes starting spring 2009. 100% vo to 65*. 5% K1 to 55*. 10% K1 to 45*. 20% K1 to 35*. 30% K1 to 10*. |
Yes the interstates I76, I70, & I25 are 75mph between urban areas. Eastern Co. is rolling high plains desert. I have to make a triangle trip from Denver to Hudson to Ft. Lupton and back every Mon. If I couldn't drive 75 for 45% of that trip, it would be all I could get done.
I'll try adding K1 to the blend. No one has addressed my second question, how many blocks/miles should I drive 25-35mph to purge my fuel system so I minimize carbon build up? Proprietor of The Blunderbuss muzzle loading gun shop. Member of Denver Biodiesel CO-OP. |
What is the GPM of the fuel feed [lift] pump? What is the volume of the fuel system downstream of the fuel switching valve? --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
Both good questions. I not sure the owner's manuel contains that info, I'll do some research.
Anyway I got a shock when I bought some K1 at a farmer's coop last week $7.00/USgal. Ouch! Further searchinf found K1 @ $4.25/USgal. Boy blending with K1 kills any financial savings. Proprietor of The Blunderbuss muzzle loading gun shop. Member of Denver Biodiesel CO-OP. |
Instead of K1, use "Stove Oil" same stuff, much cheaper. Available from most bulk fuel dealers. It's the fuel for Monitor and Toyo heating stoves.
I run what i run 100%, no purge.
Purging is for two tank individuals who post under WVO/SVO. **BUT**, if you take note---almost all blenders are also single tank WVO/SVO. David Norwood 2001 F350 7.3 DI purchased new by me and i believe it is the first DI Ford experimented with and talked about on this forum. The single OEM fuel tank only. Updated 1/2009 . HOH for fuel line heat from tank to 12v lift pump. GPI/CIM-TEK spin on filterhead and 10 micron filter. Two 12v 36" heaters wrapped around metal fuel lines. One before add on filter and one before OEM filter.dttk44@bellsouth.net Cool weather mixes starting spring 2009. 100% vo to 65*. 5% K1 to 55*. 10% K1 to 45*. 20% K1 to 35*. 30% K1 to 10*. |
That Ford 7.3 powerstroke has a return line from the fuel rail so just letting it idle for say 5 min should purge the system. Newer versions didn't return but I'm not sure of the cut off year for that update 12 years off the grid and counting |
I buy pump diesel in a 150 gal. tank in the winter and save for year round. Its just as thin as K1 in the Denver area, I have run viscosity tests on it. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
I do the same. Simple, easy, and I pay the motor fuel tax. I don't believe in cheating on taxes. --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
Pump diesel? Is this the same as off road, and who carries it?
My understanding is that winter blend pump diesel is essentially regular diesel with kerosene added to prevent gelling and aid cold weather starting. I bought 100 gallons when prices dropped in the late winter and only recently ran out. I plan to buy several hundred gallons this year.
1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
Perhaps in some regions. That wouldn't work where it gets below freezing in the winter. The wax component which causes gelling has to be removed, not diluted. It's similar to PHO/fats in biodiesel. Refineries vary the output from the processing units to provide fuel which is seasonally adjusted for the temperature anticipated. This might help in understanding how a refinery works: http://www.chevron.ca/operatio...fining/treatment.asp --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
At all stations thats the only kind they sell during the winter months, buy some diesel from any station in Denver during Jan-Feb. its the thinnest you can get, as thin as 100% K1. Not off-road, that simply has no road tax paid. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
