Sponsors    Home    Forums  Hop To Forum Categories  General Blending Discussion    VW Jetta?
I'm thinking about buying a vw jetta for the wife.
Will it like B100? I've been running my Isuzu pick up on B100 for 6 months with no problems, I never even changed the filter and she's loving it.
I'm also selling B100 to various individuals. Should I be worried? Generators/boats and trucks now running on B100 here. I'm just worried about the long term consequences if any.
Thanks for the input,
sxmbiodiesel.
Location: Caribbean | Registered: 29 May 2008Reply With QuoteEdit or Delete MessageReport This Post
What year is your Jetta?
I have an /87 that I run on b100 with no problems during the warmer months here although I did have to change the fuel filter after I had changed over (a normal ocurance). I found no noticeable difference in performance using it
12 years off the grid and counting
Location: Muskoka, Ont, Can | Registered: 23 March 2003Reply With QuoteEdit or Delete MessageReport This Post
My 95 GL likes it (B100) except when the mercury dips below freezing of course. I am wondering how it will react to blending.
Bernie
1983 Mercedes 300SD
1995 Jetta GL
Location: between a rock and a hard place | Registered: 22 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Mine had no problems with all blends. I went down to -10 to -15 on a fifty fifty blend.
Didn't notice any problems with starting at that temp. I did lose one glow plug this winter. It was about 2 years old and appeared to have more than normal ash build up. could it be from some of the heavier b100 I ran through it during the summer?
Maybe but I can't say for sure
12v Dan, what year and model Jetta do you have?
Bernie
1983 Mercedes 300SD
1995 Jetta GL
It's a 1987 1.6L turbo diesel Jetta GL
when blending are you using any heat exchangers?
Bernie
1983 Mercedes 300SD
1995 Jetta GL
No. I just pour the bio in and add regular diesel at the pumps.
Let the stuff mix up in the tank while driving down the road.
I may be getting into a newer Jetta after today if everything goes according to plan. A /97 2 liter tubo. I'll see what kind of shape it's in
The blending I am considering is with cleaned, dried WVO not biodiesel. Thanks.
Bernie
1983 Mercedes 300SD
1995 Jetta GL
