Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Making Biodiesel with Ethanol    Separating using electrostatic separation
Has anyone tried electrostatic separation while using ethanol?
http://www.make-biodiesel.org/...atic-separation.html
Location: Iowa | Registered: April 04, 2011Reply With QuoteReport This Post
The Quiet Dan; Is your question in reference to your ethyl biodiesel not separating, after the base catalysed transesterification reaction?
I had been reading how it seemed to be difficult to get separation when using ethanol, and I just wondered if anyone had tried electrostatic separation to ease things with ethanol. I have been reading about ethanol and it seems to have a few benefits over methanol but few people were doing it because of the difficulties of separation.
The Quiet Dan; I made the ethyl biodiesel separate quickly. I used lye, palm kernel flakes and ethanol to make it in a standard transesterification reaction. I used 99.5% anhydrous ethanol to start. After the reaction the reaction product didn't separate into ethyl biodiesel-glycerin layers. After a while, I added 1/2 a molar equivalent of concentrated sulfuric acid, with shaking, to my storage bottle. I neutralized the alkali part with strong acid. Decanted off about half the ethyl biodiesel. Heated the remainder of the reaction product 2 1/2 hours at 52-78 degrees centigrade. Decanted the other half of the ethyl biodiesel, leaving a translucent thick liquid(mostly glycerin) in the heating flask. I made the soap in the ethyl biodiesel into free fatty acids and sodium sulfate. I removed the free fatty acids (i think) by using magnesium silicate with heat, stirring and filtering through a 1 micron paper filter. So, no need for electrostatic separation, can be done by simple chemical means. Before I put the magnesium silicate into the crude ethyl biodiesel I distilled off excess ethanol and some water, under a 12 inch vacuum.
