WVO Design fuel pumps $50 each
I have two http://www.wvodesigns.com/raw-...table-regulator.html
WVO Design fuel pumps first one is older style that is set to 75 psi.
Second one is newer style with the adjustable style regulator.
Been sitting on the work bench for the last year might need rebuilt but $.10 cents on the dollar. As each one was $500 new.
Robert 954 266 9303
Robert
hello !! do you still have the wvo pumps? if so can you send me some pics? thanks
Registered: October 25, 2016Reply With QuoteReport This Post
Sent you a message!
Registered: September 06, 2012Reply With QuoteReport This Post
Those sold quick
Robert
Are these still available?
I'll take both if they are
Registered: January 11, 2018Reply With QuoteReport This Post
