Sponsors    Home    Forums  Hop To Forum Categories  Biodiesel and SVO equipment For sale/wanted    Fuel Tank Valve Selector WVO,SVO,Biodiesel
Did your old plastic Pollak fuel tank selector valve stop working, i.e., leaking, sticking--the plastic gears stripping?
This is what the inside of your Pollack valve looks like.
It may be time to upgrade your WVO/SVO or biodiesel tank valve!
We have been running road tests on this aluminum bodied, 3-port WVO/SVO 12-volt fuel tank selector valve (also available in 24-volt) with easily-replaceable Viton seals. It has 12-mm ports with 1/2 inch NPT threads, a maximum operating temperature of 212° F, it is a bubble-tight valve (which means it is not going to leak like some of the other valves used for WVO) and it even has a small red light that tells you when you have switched to WVO! We have run this valve in VWs, Mercedes, and larger pickup trucks with good results.
For those who are interested, email me for a flowchart of the valves’ performance.
Other details you may want to know:
Max operating pressure: 1 MPa (10 bar) = 145 psi
It will take two 3-port valves to replace one 6-port valve.
we also have 24-volt wvo valves!
anyway we have them in stock!
$49
Omar
www.omarsales.com
This message has been edited. Last edited by: Omar,
Likewise omar. How do you switch these. I am a bidder on ebay. Thank you
Registered: 27 March 2008Reply With QuoteEdit or Delete MessageReport This Post
it even has a small red light that tells you when you have to switch to WVO!
That's great Omar!
Next time I'm driving down the street with my head under my hood, I'll look for the tiny red LED to indicate switchover!
Omar,
Do you have a flow chart showing the pressure drop for given flow rates?
Location: Redding, CA | Registered: 22 June 2005Reply With QuoteEdit or Delete MessageReport This Post
Welder Roll Eyes Wink
WE are working on that ... we have just road tested this valve on vw,mercedes and a 6.9 ford f250... should have more valve data soon I will post it as soon as we have it...
omar
www.omarsales.com
Omar,
Do you know the amp ratings and current requirements for these valves? Basically I'm trying to figure out how heavy of a wire and switch I'll need to run one of these.
_______________________________________________
Location: On my computer at this moment :) | Registered: 13 October 2007Reply With QuoteEdit or Delete MessageReport This Post
We have 24 volt in stock!
Omar
wvo valve $53 each free shipping in the usa.
use inp53 as your code or email me
Omar
www.omarsales.com
What is the bolt sticking out of the side?
Asked before, not answered, how many AMPS does the 12 volt model draw while it is actuated?
I'm in Canada.... what's your Christmas special price to get one shipped and into my hands?
Thanks!
Regards,
Scott
1987 Mercedes 300D - 2 tank VO
Registered: 22 April 2008Reply With QuoteEdit or Delete MessageReport This Post
What is the bolt sticking out of the side? mounting holes on one side
Asked before, not answered, how many AMPS does the 12 volt model draw while it is actuated? less than an amp per valve
$53 each plus $19 shipping to canada
I can send you a paypal invoice thanks Omar
..thx anyway Omar. I found a locally sourced Parker 2-position 3-way hydraulic (HydraForce style) valve for $79, so I went with that otherwise I would have taken you up on the offer.
Regards,
Scott
Omar- The picture seems to show plastic in these valves (?) . What is their temperature rating ? - Thanks
1994 F250 IDI 7.3 NA E4OD
viton seal in valve no plastic in valve ... plastic electrical cover for coil... 212F is the rating
less than an 1 amp draw
we have 12 volt or 24 volt
Omar
www.omarsales.com
We have valves in stock 24 or 12 volt!
Use this code when ordering at omarsales.com
os49
And get 10% rebate
Omar
www.omarsales.com
wvo valves $49 on sale at www.omarsales.com
we have FPHE in stock all sizes copper brazed or nickel brazed
Permatex high temp thread sealant
http://www.amazon.com/Permatex-Maximum-Temperature-Seal...id=1232821788&sr=1-3
or Permatex 80631 #14 Thread Sealant with Teflon, 1 oz. Tube
http://www.amazon.com/Permatex-80631-Thread-Sealant-Tef...d=1232821234&sr=8-11
Sources for wvo thread sealant
Omar
www.omarsales.com
Hi Omar.
These valve bodies look to me like they're machined from aluminum then either painted or anodized black.
Am I right? Are they aluminum?
Originally posted by welder:
Hi Omar.
"We have been running road tests on this aluminum bodied, 3-port..."
Registered: 28 July 2007Reply With QuoteEdit or Delete MessageReport This Post
