Sponsors    Home    Forums  Hop To Forum Categories  Biodiesel and SVO equipment For sale/wanted    WVO supplies for CHEAP!
I am starting to dismantle my WVO settling setup. I ahve a few pumps and barrels to get rid of, does anyone want them in the Central FL area? $5 for a hand pump (harbor freight), $40 for a Northern Tools 10GPM diesel transfer pump & hoses, some of this and that...
DN
What are your future plans for vo?
David Norwood
Updated 1/2009 .
I'm taking a break until:
A. I get bored in the garage again
B. I find a REALLY nice 240D manual, 300D, or 190D
C. I find a pretty cheap 1998-1999 E300d, OR
D. Gasoline goes up to $4 a gal again
I am just tired of being greasy all the time, picking up oil in 90F+ heat, fixing semi unreliable cars, and generally I want some of my time back. I will be running 50%-50%in my 1997 E300D most of the time, but that doesn't require a LOT of oil nor a lot of work.
bk...If you got any extra oil you need to get rid of, Im just down the road. What else you got??
I just found a used FRB-5 fuel pump I will let go for $30. I've been using it as a biodiesel/gasoline transfer pump but it's slow.
I will buy your FRB-5 fuel pump do you want me to paypal you? thanks Omar
Do you happen to remember the model # for the northern tool pump? I'm in California but I'd pay for shipping if it's not too expensive. I imagine the pump might fit in a flat rate box from USPS. Let me know how much you want for the pump and hoses (or whatever you were including with it) + shipping. I can send paypal if that works for you? Thanks...
-David
Registered: 02 November 2009Reply With QuoteEdit or Delete MessageReport This Post
pump looks good thanks try it out this week Omar
PUmps are both gone, I'm down to stuff too cheap to ship...
What kind of hoses do you have left? And anything else. I go back and forth from Stuart to Gainesville often so I wouldn't have to worry about shipping.
Location: Gainesville, Fl. | Registered: 28 December 2008Reply With QuoteEdit or Delete MessageReport This Post
