Centrifudge wit a pump motor $400
It is an Absolute Centrifuge #003. $1500 new. It has a motor that has less than a hundred hours but it has been sitting for the last 6 months and does not turn on. It needs to be taken apart cleaned and put back together. I also have a grease pump designed for a fryer.
The best way to use a single pass centrifuge it to run it thought 5 times. Bucket above it bucket below it and a timer. Set the timer for how long it takes to run WVO from top bucket to bottom bucket and have the pump, pump it back in when it its done. Repeat 5 times. Result Really Clean oil.
$300 without the pump.
I am out of the WVO business. I have two electric cars, actually cheaper than grease and a hell of a lot less work.
Robert 954 266 9303
Robert
