Home
Forums
Biodiesel and SVO equipment For sale/wanted
Many 500 and a couple of 300 gallon Propane tank available|
Hey,
I am trying to build a pig smoker out of a huge barrel like this 1. i am curios if u think it would be able to be used for that and also if you have any pictures. Thank you Joe |
Hey Joe,
I have had several people mention building pig roasters out of these. There are several on Ebay made out of 250,300,500 and even 1000 gallon tanks. The smallest tanks, 250 & 300 gallon, are about 9'x2 1/2'. The 500 gallon are 9'x3 1/2' and the 1000 gallon are 16'x3 1/2'. If I can be of any more help, let me know. Thanks, Paul. 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
I wish you were closer to Omaha. I have a wood boiler in my pole barn that will heat the shed plus my home this winter. 1000-1500 gallons of storage would allow me to fire it only when it is convienent for me and tap the stored hot water when I'm at work, sleeping, etc. The boiler is made to "idle" when there is no demand for heat but it runs much more efficiently "wide open" and no smoke or cresote. Others with boilers like me (Hearth.com forums) have been using old (or new) propane tanks but old ones have to be cleaned well because of the mercaptan. The ideal situation would be a tank not up to snuff for propane but still able to handle 180-190 degree water. They would be under very little pressure compared to propane use. What does it cost to transport tanks? I've just seen the little trailers here that carry one at a time. Where do you find expired or "flawed" tanks? Is there a local business in my are that may have them too?
Randy,
You might try looking for old Anhydrous tanks, I would think that there would be some in Nebraska with all the corn that is planted there. They are basically the same tank. I haul the tanks on my flat bed trailer and pyramid stack them and bind them down with chain binders and straps. 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
I'm in Ohio and would love a 50-100 gallon tank for a super sucker if you ever come across one.
1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
rsr911,
I will see what I can find. 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
Paul,
what are the dimensions of the 1000 gallon tanks? |
The 1000 gallon tanks are 16' by 3 1/2".
Paul, I need 2 500 gallons tanks for use with water. How do I contact you? What's your phone number? Dave Bruce 517 436-3342
Hey Bruce,
I sent you a PM. Thanks, Paul. 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
I have many 360 gal tanks if any one needs them.
I can get the exact measurements off the data plate as needed. They are short and stubby tanks 41" in diameter but I don't remember the length, maybe 5' or 6' long. I'm in the southwest tennessee area. $200 per tank. Randall |
I see I should have posted here. I'm interested in the 300 gallon tanks, and I'm in Ohio, though on the other side. Do you know the dimensions?
Thanks! |
Whoops, I see the dimensions too. And I see your phone number. Amazing what you can find out if you bother to actually read!
Hi Paul,
I'm looking to get a 300 gal tank. Do you have any available? Thanks, Ben |
Paul,
I'm looking for a tank I can use for propane. How do I get a tank recertified or do you know of anyone in the area selling tanks used or refurbed? Thanks! |
Ben,
I currently do not have any 300 tanks available. I will post when I get some more in. Thanks 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
JW,
There were some refurbished propane tanks in the NW Autotrader magazine a few weeks ago. You might go online autotrader and see if they are still there. 2001 ford F350 4wd crew cab 6spd w/stroke and 100hp chip 1983 MB 300td great old car! 2005 jeep liberty crd IH cub with kubota Makers of the almost famous wvo collection lids as seen of B100, Utah biodiesel, Ever Green Renewable Energy and on Ebay |
Paul,
What's your current status of 500 gallon tanks? Thanks |
Still have some 360 gal and 500 gal tanks if anyone needs them.
I'm in southwest TN. $150 and $175. Thanks,Randall email for dimensions and weight if needed. Weight is approx 1.8 lbs per gal of tank. So a 360 gal is 648 lbs. Lot of Steel |
Home
Forums
