Home
Forums
Equipment Articles- Appleseed Processor, standpipe wash tank, and more
Building an appleseed
Read-Only Topic|
Jaxom,
Pull out the yellow pages and start calling all the hardware stores and plumbing supply stores and ask for a return, or scratch & dent, or demo water heater. Sometimes you can find one as much as 60% off. In Chicagoland, there must be hundreds of places to call. |
scour Craigslist, or if your local paper has a "recycler" section keep looking there as well. You may get something for very little or even for free. It has happened.
Bernie 1983 Mercedes 300SD 1995 Jetta GL |
I'll think about those options. Where ever you can save a dollar is great, eh? Still wish I knew how much volume in gallons a 100# propane tank would hold? Anyone have any ideas?
about 25 gallons I think
Hey Jaxom. I found a dented 40 gallon electric hot water heater for $110 --- the place I got it from had a contract with insurance companies to get goods out of damaged stores from Hurricane Katrina; think Lowes and Home Depot stores that might have had the roof ripped off in the hurricane. The insurance company would like to salvage some of the goods. There were water stains about 5 inches up the sides; and a very small dent about in the middle of the tank and I do mean small. OLD hot water heaters can also be in good shape. I made a sucker tank out of one...it did have one small pin hole in it; which I glued. I wouldn't use this tank as a processor, but it makes a great sucker tank. And the hole is on the top side.... Keep Looking and Good Luck. daw 1986 Mercedes 300SDL 2000 Dodge Cummins |
Hi Jaxom.
Here in the UK all compressed cylinders have to have certain stampings put onto them when they are made surely yours have the same ? The gas cylinders you mention should have things such as tare weight, gross wht, pressure, capacity in litres or gallons etc I am using a gas cylinder myself for the reactor vessel, PLEASE BECAREFUL when cutting one open as I have found that some of the gas may have been absorbed by the metal. I opened the outlet and filled the cylinder with water to remove any gas fumes then let it stand for around a day then cut it open, I may have been over cautious but i`m still in one peice, (not allowing for surgeons ). Hope this helps Best wishes Paul |
Read-Only Topic
Home
Forums
