Home
Forums
Equipment Articles- Appleseed Processor, standpipe wash tank, and more
Questions about processor upper fittings
Read-Only Topic|
Sure...
Here's a labelled diagram of what I use them for: I use all three holes. -Graydon
I plan to use my sight tube only to measure the amount of oil and then drain it and isolate it so that the system runs on hard pipe.
Is there any real reason to have the sight tube connect back into the tank? Seems to me that if it is open on top with a elbow so dust doesn't fall in it would work just as well. Anyone see a downside? Known problems? Andrew |
Graydon,
Oh, by the way, thanks for all the work you put into labeling that diagram. Real helpful! Andrew |
Nah...no real reason to connect them back.
I guess it just prevents spillage. If you could ensure you could keep it clean & free of debris, you could probably get around hooking the top of it up to the tank. Glad you liked the diagram. It's not "the gospel of how to build an appleseed", but just a mere example. There's lots more here: http://www.biodieselpictures.com -Graydon
Must the pump return tubing/processor inlet enter the top of the reactor via the cold water inlet, or does it matter? Is there a way to remove the dip tube or does it matter if it remains in place?
Graydon, why does your Processor Vent outlet on top have a ball valve? When would you want to keep the system closed, and when would you want it open? (Basically, isn't the pressure relief valve enough to vent to the outdoors?)
Read-Only Topic
Home
Forums
