Home
Forums
Equipment Articles- Appleseed Processor, standpipe wash tank, and more
drying bio in wash tank with wash water still in tank??
Read-Only Topic|
Been working for me for the last 4 years--
Lower the wash water level an inch or so below the stand-pipe. I then dribble the wet BD thru an electric frying pan with a few hole drilled in it and recirculate until dry. Decant thru the stand-pipe above the water level. ReM B100-- 2004 Motorhome CatC7 1987 Mercedes 190D 2.5 Turbo(possibly for sale) 1983 VW Pick-up (Caddy) 1.6 Turbo Southern Oregon |
We use a conical bottom drum that holds 300 Litres of WVO from start to finish takes +- 7 hours. All done in the one drum.
Processor is 2 HDPE 200 L drums welded together, a cone welded to the bottom and a which could be clamped on if needed. WVO is heated up midday, titrated and mixed for 2 1/2 hours left overnight. Next morning Glycerol is drained off, heater switched on, and mist washed 3 times, violently washed 2 more times, and final water drained off. Heat pumped up to about 70*c and spray dried against the tank wall with a fan blowing over the top. 1 1/2 ours all done, into storage, and a new batch started. All done in one tank, 300 Litres a day, no fuss no bother, passes all tests. |
ReM
do you have a pic of your drying setup it would help me design my setup thanks |
Might take a couple of days to take and post one-- Just take a Facet fuel pump and pump from near the bottom of the BD into an electric frying pan set on low. Drill enough holes about 1/4" or so up from the bottom of the pan so that the BD drains a little faster than the pump works. BD is dry when the bottom of the pan no longer has bubbles and a flashlight beam is not dispersed when shined thru to the bottom of the bd in the drum. I use a 55 gal HDPE drum with the top cut out so that a barbeque grate sits on the remaining edge and the pan sits on this. (this also allows me to replace the grate with a large plastic planter inverted over the drum to house my mist washing set-up thus keeping the overspray from escaping) Use bulkhead connectors from ACE hardware for the drain / external stand-pipe / continuous flow mist overflow system. ReM B100-- 2004 Motorhome CatC7 1987 Mercedes 190D 2.5 Turbo(possibly for sale) 1983 VW Pick-up (Caddy) 1.6 Turbo Southern Oregon |
[QUOTE]
Processor is 2 HDPE 200 L drums welded together, a cone welded to the bottom and a which could be clamped on if needed.QUOTE] What did you use to weld the HDPE drums together and the cone to the bottom? Thanks, DD |
We have dried BD in the wash tank by pulling the air bubbler up into the BD. It takes a while, but you can dry the fuel as it sits on the water.
DD |
Hi Dandy Don, we farm our drums out to a plastic fabricating company, they plastic weld them together using a type of heat gun specially designed to do this, they also cut and weld the conical bottom on. Being a chemical company, we have plenty of blue HDPE drums available, works like a charm. Jimk.
do you guys know if marine epoxy is of to use with biodiesel. I used it on the bottom of my wash tank.
so is should not realy come it to contact with much bio any way.. |
Read-Only Topic
Home
Forums
