Sponsors    Home    Forums  Hop To Forum Categories  Equipment Articles- Appleseed Processor, standpipe wash tank, and more    Material for standpipe for poly tank
Read-Only Read-Only Topic
Ok, perhaps this has been answered before, but anyway, Is the correct material for the stand pipe in the poly tank design black pipe?
Alan M
Location: Somewhere on the Colorado plateau | Registered: 31 October 2006Report This Post
Hey Alan,
I use schedule 80 PVC for standpipe in my poly wash tank.
E
Biodiesel works in Driptorches, too! (Card-carrying Pyro)
2003 Jetta Wagon TDI GLS
2001 Chevy Duramax CC 4WD (101K miles)
1990 VW Passat Wagon TDI (206K Miles) SOLD!!
1983 Isuzu P'up LSD Long Bed 2WD (325K Miles)
Homemade Biodiesel since 2002
Location: Flagstaff, AZ, USA | Registered: 22 April 2002Report This Post
I ended up using black pipe. I think I may change to PVC. I'm using a poly wash tank & metal drying tank. I'm almost finshed with the modifed gadgetarius model. I'll call you for the 1st brew.
Alan
A 2" black bung w/ 3/4" inside bushing fits into the NPT opening of a poly barrel. You can easily thread both ends of the 3/4" with a 3/4" pipe tap ($15 new) on the inside (only the inside needs this). Then screw a close nip on the outside, and your riser to the inside. I like to tighten them until there is no gap between the two pipes. You can feel inside through the close nip. The pipe will solidly stop turning at that point.
Location: State of Confusion | Registered: 08 December 2007Report This Post
I sell a port for the 2 inch bungs that has two 3/4 inch NPT fittings threaded on both sides. I make them in steel and plastic. Sorry for hijacking the thread. Big Grin
WWW.RillaBioFuels.com
