Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Biodiesel Quality    Thinning out bio for the winter.
Will E-85 work as a winter thinner for bio? I know kero is best but i had to drain the the tanks of two mis-fuled vehicles at work. One was a gasser and the other a diesel. So i have about 20 gallons of mostly ethanol, partly gas and a little diesel all mixed together. The best part is i can get it for FREE.
I was think about a 15 to 20% mix as the winters are not that cold here in S.C.
thanks
Location: Greer S.C. | Registered: June 24, 2008Reply With QuoteReport This Post
I would imagine it would blend fairly well, what kind of truck do you drive? Newer models can be trempermental.
I would throw that blend in my truck, but its an old cummins and will burn about anything except water. Big Grin
Location: Buckeye | Registered: July 07, 2009Reply With QuoteReport This Post
I would throw that blend in my truck, but its an old cummins and will burn about anything except water. Big Grin[/QUOTE]
I hear you.
yes i also have a every thing bunner. it's an International T444E traped in a 99 F-250, i think ford renamed it the 7.3 power stroke.
Thinning bio with E85 in the winter sounds like a recipe for disaster, people use things like kerosene and pump diesel to help lower the cloud and gel points of bio, kerosene and pump diesel still have the lubrication qualities a diesel needs to lubricate pumps and injectors, I may be FOS But I think it's a bad idea.
I concur... IMHO alcohols of all kinds should never be used in diesel engines.
Use seasonal pump diesel, or kerosene, or stove oil, or jetA, and gasoline sparingly up to 5%.
thanks guys, i guess a few gallons isnt worth the risk. i will heed the advise. so......what elese can i do with 20 gallons of mixed up, wanna-be fuel........lawnmower?
Remove the alcohol by evaporation or distillation. The non-volatile component can mix with diesel fuel, BD, or VO.
Shoot, were not talking about a 2009 Dodge Cummins with six computers and electronic injection here,
Ive burned far worse in my old Dodge and still have the original motor and injector pump at 700K. If blended low enough Im sure his old diesel would be fine, these old gals are a lot tougher than you would think (assuming the old powerstroke is built like the cummins Big Grin)
If you have just a few gallons mix it in with pump diesel two or three gallons at a time.
You've burned mostly ethanol, some gas and a little diesel all at one time in the same tank in your cummins?
If blended, you bet. We aren't talking about throwing it in straight here.
In other words, Team is asking if it can be used as an additive for a winter blend not to be used directly as a fuel.
I don't think anyone here would disagree that it would improve gel points, although it may be a good bit tougher for the engine to burn up in cold weather due to their lower propensity to pre-ignite.
I missed this post of yours Fab, basically I concur Big Grin
Many pump diesel fuel additives/conditioners are primarily methyl alcohol (methanol) based. A little ain't going to hurt but I wouldn't be one to encourage heavy use, and the mount that would be required to "thin out for winter use" would be prohibitive, IMO.
yes, i was thinking the same when i ask the orignal question. it does make sense that a lot will do some damage of some type. i brought home a 6 gallon bucket today and will mix it sparingly. just a quart or so per 15gal of bio. i just hate to see energy go to waste.
thanks for helping me out
I wouldn't go that high myself, but then it's not my pump/engine :-) That's a litre to 60 ratio; WAY too much. Even in pump diesel it is recommended to only use a cup to 1,000 Lt's of conditioner and that is for class 8 trucks that run through fuel like ducks go through water.
ok, so i got this stump in my back yard i'm going to burn-out this weekend......................lol
