Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Biodiesel Quality    methanol mix pump....
can anyone suggest a methanol mix pump (for methoxide) that is air powered
Jetta 2002 ; 6 hole nozzles, chip, yellow koni, gli springs, neuspeed RR sway bar, skid plate, SS brakes, TT shifter, TT bushings, GTi FR brakes
Jetta 2006 chipped, Bilstein Sport, Neuspeed Sport Springs, Neuspeed endlinks, DG SS, Evolution skid plate, Eibach RSB, B100
Location: Montreal | Registered: August 06, 2005Reply With QuoteReport This Post
2013 sponsor
Air driven pumps almost always take a lot of cfm to run. Air operated diaphragm pumps are solid performers but even a 1/2" pump will take probably 12cfm, or a 5hp compressor. You can also get an air driven mixer that enters a 55 gallon bung (2" npt) or clamps onto the side of a vessel.
How large a batch do you run?
'82 VW Rabbit diesel 1.6l na
'83 GMC 6.2l Class C RV
'85 F-350, 6.9l flat bed
'85 E-350, 6.9l cube van
2 Mercedes 300SD's
