Sponsors    Home    Forums  Hop To Forum Categories  Biodiesel Quality    3/27 Failed - Need Input on what to do!
I have a biopro 190 and put wvo that titrated at 1 - assuming it would easily convert to astm - The biodiesel has already been washed three times and dried. I doubled the 3/27 test so I can easily see any remnants floating around. It looks like chunks of fat, not dark in color just white chunks that do float to the bottom. Does anybody have any input on what this might be? Do I need to rereact or should I do another wash cycle? Could it be soap that wasn't washed out? Any info much appreciated.
Location: Mendocino County California | Registered: 23 October 2009Reply With QuoteEdit or Delete MessageReport This Post
Do a search with the "FIND" button above for the term "white flakes". There are a couple of threads dealing with the problem, which seems to be feedstock related.
Norman
I have seen the white flakes in the 3/27. I think it is a result of carbonation of the caustic that was used. In the past I had it appear when using hydrogenated feedstock but not in others. This had me thinking the feedstock may have been the cuilprit. But I looked at the 3/27 samples from both batches about a week later and noticed that both had the white flakes. The flakes just didn't show up in the non hydrogenated tests until some time after the others.
If you can accumulate enough of the white stuff, you can see if it is soluble in water. K or Na carbonate is soluble in water but not in methanol.
Check the methanol you are using for the test. I kept a mason jar full of methanol aside just for 27/3 testing. For some reason moisture from opening closing or being in the light maybe affected it and my tests were all failing. I'd reprocess and wouldn't get any more glyc. and still fail. I changed methanol and the same batch passed as did the previous failed batches I had stored. Just a thought.
2006 Duramax Tuned with EFI Live
2005 Sprinter Work Van
http://s132.photobucket.com/al...uilders05-008019.jpg
Location: NJ | Registered: 29 March 2008Reply With QuoteEdit or Delete MessageReport This Post
