quote: How did your test go?
I tried the hot pan test and the bio cleared up quite a bit but still didn,t have the sparkle that I think it should have. The hot plate took the sample up to 250F, there,s no way I can heat a big batch to that temp. I use a cone bottomed 55 gal drum with a water heater element and heat to about 130 F and circulate thru a shower head with a fan blowing across. Sometimes this works good and other times it doesn't clear-up like I think it should. I got about 250 gal. of bio I'd like to try out in my furnace . I had problems last winter with the nozzles plugging up but that was before I knew about doing 3/27 test.
| Location: western new york | Registered: 19 November 2008 |    |
quote: If anyone in your area has either a carbide manometer or a Sandy Brea test kit thay could tell you exactly how much water your bio contains
i don't know of any homebrewers in my area. It would be nice if I could find someone that's "arting around with bio .
quote: Yeah, it sounds like water. Do a hot pan test to confirm.
If you do a hot pan test, if you have time, chill it down as cold as you can without gelling. See if it stays clear. I am interested in how well these two tests correlate.
| Location: Northern California | Registered: 27 February 2006 |    |
quote: If you do a hot pan test, if you have time, chill it down as cold as you can without gelling. See if it stays clear. I am interested in how well these two tests correlate.
Give me a day or two to take the samples. I'm going to do a vapor test and frig test with samples from the top and bottom of the tote.
quote: Try blowing hot air from a paint stripper heat gun instead and Im sure the system will work better.
At times the fan seemed to cool the bio down . I agree with the idea of using heated air , its something I'll have to try.
