Some people are successfully using the Master / Airtex E8016S low pressure univeral electric fuel pump (about 2-4 psi ) mounted near the tank as a WVO helper pump in the VW s and Mercedes .
1994 F250 IDI 7.3 NA E4OD |
I could not add a pump to my 03 as it would not allow my looped purge to return towards the veg tank. The pump was a oneway device.
Merk 03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves |
I pump with a Carter pump 5 psi,though I will go back to a 8psi.I have a FM100 filter that lets me loop return lines to it.
