Get it steam cleaned.
where should I go to get that?
Some of what you think is algae could be salts from a WVO reaction on the copper in-tank HE ( heat exchanger ) . You could switch to an aluminum HE or coolant heated pickup and add a FPHE (flat plate heat exchanger ) . Do some searching these forums for flat plate heat exchanger , and coolant heated pickup . The thread " tank ideas " has lots of pictures too .
1994 F250 IDI 7.3 NA E4OD |
To clean a greasecar tank, you just need to take the access hatch off and wipe it out. You can put some biodiesel in there to clean it IF you put a ball valve on the coolant line running to the tank and shut off the heat.
I've been doing some research on FPHE. I am a little confused as to where I would install it. Do I remove the tube HE from the inside and replace it with a FPHE? Greasecar has them for $250 including all the components. |
No, you want your FPHE to be up front right before the IP for max heat prior to injection. They are not intank heaters. They exchange coolant heat directly to heat your fuel. Dudadiesel has better prices than greasecar. a 10 to 15 plate exchanger will be all you need for a tdi.
Merk 03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves |
Merk, Where could I get fittings and hoses to go with the FPHE? Local hardware? And what fittings do I need? Also where could I pick up some PEX fuel line? |
Here's a parts list for HIH.
Parts from McMaster Carr – #50985K74 Brass “T” 1/2” NPT #5405K12 All-Flow Red EPDM Rubber Multipurpose Hose 3/4" ID, 1-7/64" OD, 200 psi #50915K325 General Purpose Brass Compression Fitting Male Straight Adapter For 3/8" Tube OD, 1/2" NPT – Tube x Male #5346K68 3/4” ID Barb x Pipe 1/2” NPT #5346K66 5/8”ID Barb x Pipe NPT #5177K16 Aluminum tube 50’ |
