I will at Tax time use Omars switches.The manual truck valves are over $65.
They are here for $24 or 27:
http://www.discountmarinesuppl..._WAY_FUEL_VALVE.html YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
thank you gentlemen, i'm trying to find out re: the water hose valves which are cheap and may work as well... thanks again sincerely, mcarman
almost any cheap valve can be rigged to work for a while. Sensible people pay more for longevity and reliability; for others these factors are not important. Someone who lives in the southern regions where a valve failure is a minor inconvenience may think differently from someone who does not want things to fail in sub-zero winter conditions.
--.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
Another source . Industrial valves with teflon seals but shorter stem than the marine valve mentioned. However, the shorter stem may make mounting more difficult. Mcmaster.com probably offers something similar .-
http://www1.mscdirect.com/CGI/...ACHE=000000107353086 1994 F250 IDI 7.3 NA E4OD |
