Sorry I don't have a lot of specifics.
There were notes earlier about clone Pollack valves on E-Bay. Make sure you are getting yours from a reputable source, or otherwise verify genuine valves. You might be able to do away with the selector valve all together by putting in in-line one-way valves and just selecting which electric fuel pump to engage. I'm not sure about the return lines, possible routing them to the fuel filters (or thereabout). |
Normally I 'm not so abrupt but get rid of that 6 way polick valve and go with 2 3 ways I spent a year messing with cross contamination and 3 ruined polick valves Now its fine with 4 mile purge times no more hard starts.Some one will attack me on this but they've just been lucky with there 6 ports. Over at Frybird they have some nice diagrams to follow.Hope this helps you out.
Would suggest taking the pollack valve out of the system and replace it two solenoids, loop the VO just BEFORE the VO fuel pump. Very easy to plumb in place of the 6 way. Have been running for three yrs on the above system with no problems.
I guess there's always an exception. I'm running three Pollocks and they all have about 5000 miles on them. They are all well filtered before the input. The veggie has run near 190 degrees at times and through the valves. Two are from Ebay and one is from Auto-Zone.
Wayne... Winter Haven, Fl. |
I have been running two 3 port pollacks without any problems. roughly 50k
Merk 03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves |
WHat I did was put in 2 new fuel tanks, 2 walbro electric pumps and a Vegpower 3 way electric valve. I dumped the 6 way as I was just plugging them up with crap from the old tanks and not allowing fuel to get thru the pollak valves. The tanks were cheaper to buy from advance than to take them out and have them boiled out. It was 100 bucks each for the new tanks and the radiator guy wanted 75 to clean them out. No problems since.
I have about 20k on a pollak on one vehicle, and about5k on another. So far so good. I have seen a number of post on frybrid about trouble with them thoug, so maybe I'm on borrowed time.
You folks may want to check out this 3 way vavle
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/959605551/m/9731029162 here is what a leaking pollack looks like Did your old plastic Pollak fuel tank selector valve stop working, i.e., leaking, sticking--the plastic gears stripping? Omar |
I suggest going with 2- 3 way manual valves mounted through the floorboard.
They are more reliable and you only have to buy them once. http://www.libertyagrifuels.com 1995 Dodge Cummins W/ Custom 2-Tank Setup and 10 K miles on veg oil so far. 1984 300D-Daily Driver No Mods single tank and 20 K miles on veg. |
Heck I use water hose valves with fittings from Tractor Supply,like not over $5. each.If it stops water at 40 psi,It works with diesel or grease easy.
I can certainly see the appeal of this approach. Regards, Scott 1987 Mercedes 300D - 2 tank VO |
knox bio benz, specifically what valves do you use? i'd like to use that 3 way system, if i could with an 88 190d. mcarman
