quote: Originally posted by kevinh: My biopro tripped during a batch. Now the methoxide mixing motor is making a humming noise but won't run.
Nobody home at Springboard (Saturday).
I did a hard reset on the machine but the mixer motor or methoxide pump still won't run.
Anybody here ever run into this and know how to reset just the pump?
The methoxide and methanol in pumps are the same, just swap them out for now. The pump is easy to dismantle, you can pop the head off with four screws and then see if the motor is frozen or the pump is locked. Mine froze up because regardless of all the preaching Springboard does, they assembled it with teflon tape instead of sealant and big chunks of it went into the gears. Reach inside the tank with a channel lock pliers to loosen the fitting, remove the nut, pull the four bolts holding the two pumps together and unhook the wires. Lift straight up and out. Five minutes at the most. Norman
| Location: Lincoln, NE | Registered: 10 April 2006 |    |
member 2009 Sponsor utahbio.com
I'd recommend moving that number to "after 4-5 batches". Especially if you're using NaOH. -Graydon
