member 2009 Sponsor MurphysMachines.com
What two pumps are you using? If its the little blue pumps, then 1 inch will be plenty. www.MurphysMachines.ComThe best Do-it-Yourself Construction Plans on the Internet! Waste Oil Heating - Biodiesel Systems
quote: Originally posted by marvingvx: I would think that there can't be too much if in doubt use 1-1/2". In biulding my new processor I am using 2 of Murphy's big pump's with 1-1/2" suction port's. I chose to use 3" plumbing tee'd at the bottom with bell reducers coming out of the tank. Is this safe as sorry or is this just overkill? Should I drop down to 2"?
3 inches is a bit over kill but no harm done.... 2-1/2 would have been more than enough. www.MurphysMachines.ComThe best Do-it-Yourself Construction Plans on the Internet! Waste Oil Heating - Biodiesel Systems
quote: Anyone run this setup before? I am worried the 1" will not provide enough volume for the two pumps with 3/4" outputs.
I do, more or less. I have a 3/4 outlet from the tank to a 1" inlet in the larger pump and a 3/4" inlet in the smaller. The smaller pump has a 3/4" outlet and the larger has a 1" outlet. A reverse path through the smaller pump provides a second input to the larger pump during processing, so in that case two 3/4" inlets provide for a 1" outlet; backwards of what you propose, and it seems to work OK. If you are using 2 of the smaller pump, I think you'll be fine. If its a bigger one, its not gonna be enough. My big pump creates so much vacuum in the 3/4" inlets that it sucks air through the 1-way valve on the methanol port and collapses the methanol jug. I just choke the big pumps outlet down some to slow the exit and increase the "residual time" of the fluid in the bigger pump.
| Location: Southern WI, USA | Registered: 18 May 2006 |    |
| Location: New York | Registered: 03 December 2004 |    |
wow what a fantastic score. Im getting a free 372L propane tank from the propane suppliers once they take all there valves or whatever off. You could say Im pretty excited  Poly cone bottom reactors are good, but Im board, Its time to start playing with vacuums..
