high will be from 150 to 250, low will be from probably about 50 to 150. most of your stick welding will be done in the 110 to 120 range unless you are welding plate over 1/4". This seems like a very old machine, and is probably a dc only unit. These are easy to use. just do some practice runs . keep a short arc and don't travel too fast. 7010 may be a bit hard to use for a first timmer, since the flux is heavy, and can roll in front of the molten puddle, and cause flux entrapment in the weld bead. I would start with a 6010 or 6013. the weld bead is not as smooth as that from the 70 series rod, but they are good to learn with, strenght 60 thousand lbs /squ " vs 70,000. Tom
" I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005.
| Location: Manitoba Canada | Registered: 24 March 2009 |    |
I would expect it to have seperate AC and DC output connectors if you had a choice, without these it could be either AC or DC. Open up the case and look for 4 power diodes mounted on some type of a big heat sink, they will look sort of like 3/4 inch bolts and have heavy wires connected to them, these convert AC to DC, if not there then you have an AC welder.
If you have an adjustable current setting on the top of the unit you may also have a plunger knob there too, if so, you pull the plunger up to allow you to move the amps setting knob, you then need to push the plunger full down to clamp the internal sliding contact firmly in place, not clamping it will cause arcing at the slider, this will likely burn up the transformer's slider windings in the first couple seconds of use.
| Location: fisher,illinois,usa | Registered: 03 June 2003 |    |
DoubleD -your welder has only 3 plug ins for the cable so it is an AC machine. one is common one is high, one is low. Be sure when you purchase rods, that they are for an ac machine. although all electrodes will work, some dc electrodes will be sticky and hard to strike an arc. Tom
member 2009 Sponsor
Thanks Tom, That's what I was wondering. I guess now I need to dig a trench to put a panel in the shed to power this baby. Great, more work.  I have a good feeling about this one though from what I've been reading these oldies seem to be pretty simple and long lasting.
| Location: central virginia | Registered: 13 March 2008 |    |
I have not seen one of these welders myself but it sounds like a simple AC transformer type welder, the second smaller coil may be what is called a stabilizer coil, these are simply heavy wire wound around an iron core to create an electromagnet. The stabilizer coil helps make the arc run smoother, it compensates the current a bit as you make the arc shorter or longer when running the weld bead. I found THIS short discussion, sounds like the same welder, not a lot of info but it sounds like it is a good basic AC buzzbox welder.
That looks similar to my AC buzz box welder. I also have the high and low taps. quote: I don't see any kind of heat sink inside. Just 2 coils of wire, a smaller one centered above a larger one, two heavy cables going from the center coil to the switch, and what may be a big magnet(?) going up and over the coils of wire. Sound correct? The smaller coil is likely moved in and out of the larger coil by your current adjustment knob. The deeper the smaller coil goes into the larger coil the greater the current thats available. This can also be achieved by a shield that can be lowered around the inner coil. Mine seems to work great but I have nothing to compare it too quote: I guess now I need to dig a trench to put a panel in the shed to power this baby.
Its amazing how much money I guy can save making his own fuel eh? LOL cheers, Jon
| Location: Wellington County, Ontario Canada | Registered: 07 February 2008 |    |
member 2009 Sponsor
Thanks for all the help on this one guys, I sent an email to the tech dept. at a company called arc products ( http://www.arc-products.com/) and after some back and forth emailing, they were able to I.D. the welder and can even provide an owners manual. They have been a great resource. It is a Model M C M 1353 230V A.C. only transformer arc welder.
