Sponsors    Home    Forums  Hop To Forum Categories  Biodiesel Equipment    blue pump temp. ceiling
Those of you doing meth recovery with the little blue pump, what are the highest temps
you recover at and how long do you keep them there?
Registered: 24 June 2009Reply With QuoteEdit or Delete MessageReport This Post
I used to the little blue pump for methanol recovery...
I would keep the pot temp below 200F or you might loose the shaft seal...
I lost a few that way before I upgraded to a larger pump with a higher temp rated seal.
-dkenny
