Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Biodiesel Equipment    Vacuum oil collection trailer
Closed Topic Closed
This is a picture of my most recent vacuum oil collection system, summertime only. More pictures and info here
As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank fuel system installed january 2010, now running on a heated blend of 90% veg/5% diesel/5% RUG (no acetone or turpentine, heat replaced these).
Location: fisher,illinois,usa | Registered: June 03, 2003Report This Post
Closed Topic Closed
