Biodiesel & SVO Home
Biodiesel & SVO Forums
Biodiesel Equipment
hot water heater has only two ports on top...Help!|
I'm a noob to bioD. I just purchased Graydon's instructions for the appleseed. I was able to ge a used water heater for free, but once I got it home, on closer inspection, I see that it only has two ports on top, the hot and cold water ports, with no third port for the anode thing. Will this work? If it will, what mods will I need to make? I have attached a picture (hopefully I did that right). Thanks much!
Turn it upside down. Do a search for "Apple Turnover"
So is the Apple Turnover my best bet then for a two top port HWW? This will be my first one to build.
Thanks, 1984 Mercedes 300D |
I make a special port that allows you to put two 3/4 inch pipes into the two inch bung on a drum. This allows you to make an appleseed-like processor from a drum with no welding or mods to the drum. About the same size batch as a WH, but less expensive, and modular. There is no limit to how many drums you use, just transfer the fitting from drum to drum. HTH
Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
Biodiesel Equipment
