This is the one I use, although I had to go through another one to get to this one. The first one was defective (as so many things from Northern Tool seems to be). If you get it, do it in peerson and inspect it right there at the store, and assemble it before you buy.
My first one's locking nut wouldn't screw on correctly and this ended up making the whole thing useless, but for parts. I've been using the second one for a couple years now and can't even begin to guess at how much methanol I've pumped with it, but it's been SEVERAL drums worth. I just hooked up a length of hose to the spiggot and then pump away. Graydon has this nice pump on his site if you don't trust the quality of NT's (I think I was just fortunate to get a good one second time around). HTH **My reactor/processor :B100WH.com **The Colaborative Biodiesel Tutorial **B100 Heated Winter System ** Biodiesel Glycerine Soap - Make & sell soap from Biodiesel Glycerine |
ski2liv
-are you looking for a pump to remove methanol from a drum? I found and air oil barrel pump that when connected to a metering unit I picked up at northern tool allows me to meter directly from the barrel into the methoxide mixing tank. This is not really a pump as the name implies, but to use it you attatch an air line, it pressurizes the drum, and out the tap comes a steady flow of methanol. I found this in Canada at princess auto, a very similar outlet to your northern tool. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
SA-WEET! Affordable as can be... I just couldn't justify $130 or more to pump methanol from a drum! THANKS! |
Hey Tom, Can you elaborate on the Power Fist metering unit you speak of? I have a princess auto not far from me... Jon |
-the barrel pump is PA part #8205494 (pg 53 cat#267) The northern tool tool didgital flow meter is 10930-1907, brand name GPI (Great Plains Industries) the unit I purchased measures in US gallons, but reading the litrature, says it is available in Canada in ltr. Not sure where, but a farm supply shop would be a place to check. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
