I'd thought I'd post a photo of my rotor even though its still in the making.
'84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough CF_Rotor_1.JPG (44 KB, 56 downloads) CF Rotor |
Looking good dkenny!
Nice to see the use of a standard Coors Light beer can for reference on size |
I don't know about "pre-medicate"; that might negatively affect your judgment and lead to a bigger issue, but SURELY you should post-medicate every time!
its getting closer..
its now got 3 layers of resin on the outside.. now I need to turn the outside again, the inside and balance the unit..then turn the hole for mounting it to the lawn motor spindle..then testing?? I know its slow coming but its getting there.. at the moment I sure the wood will hold..I ran it around 4k RPM on the lathe unbalance...the rotor stayed together..no problems...now if I could find a used lathe?? turn on end..all done after I get it balanced..I'll crank up the lathe to its max..this should be well over 6K..way more that I run the CF at.. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
Dave
-a lathe on end! now that is creative thinking " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Sorry Tom..just one for the moment..I want to make sure the wood will stay together..
if I was making it out of metal..I would try making several.. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
You trying to say something dkenny? Can't wait to see it in action, hope you get it done quickly! |
ah..nope
got any for sale? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
