buckeyebiodiesel,
where you put the oil in and where does it come out.. got a simple diagram? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
Dkenny, I don't have any diagrams, but the concept is pretty simple.
I have a feed tube that drops into the rotor through that hole on top (where the beer is The extreme G-force causes the heavier particles (and liquids like water) to get stuck to the inner wall and the lighter materials i.e. now clean WVO or biodiesel to build up until the rotor is full and it comes out the 'beer hole' much like this test we did below: Here we were testing the unit for the first time with City of Tempe tap water. It ran for one hour. The rotor was full of a brownish/black sludge (which would be the heavier particles) when finished. In the pic above you can see the water (in this case the lighter material)escaping out our 'beer hole' watering our lawn I have since put together a container to 'catch' this mist (now oil based) and pump it into one of my storage containers. And thats basicly the way how a rotor type centrifuge works. I will get into more detail on the bearing set / shafts / couplers / bushings / motor / etc as this thread continues. Its a bit much to put up all at once, also I want the community to help come up with better ideas on how the average bio-brewer can make one at home for cheap. |
Many of us want a low cost open bowl type centrifuge are a looking for low cost alternative ways to construct it. Thanks for your help .
(Other CF thread for reference. Start with last page and read back - LINK FIXED- http://biodiesel.infopop.cc/ev...51/m/9751014751/p/14 This message has been edited. Last edited by: rkpatt, 1994 F250 IDI 7.3 NA E4OD |
What is the "trigger" to know the bowl is full? When its running at speed, is it easy to see its almost ready to overflow with crap? Or do you only know after you notice junk spewing out?
Ryan, yes you can see the material building up in the bowl. Its really neat looking. It looks like a wall of oil slowly moving to the 'beer hole'
This unit sits in a container that houses the rotor/bowl and stand with the electric motor outside (to prevent it from getting soaked in oil). I used a piece of Lexan for the top (much like plexiglass) so I can monitor whats going on in the container. It's really easy to use once I get it to full RPM. If I notice sudden changes in the color of the mist escaping from the rotor then it is probably about full and needs shut down for a cleaning. Once done, I fire it back up and let it continue cleaning my WVO. I am setting it up this morning to remove water from some badly contaminated oil. I expect two quick passes should get it to pass HPT and vapor tests. Guess I'll find out later today if my assumption is right |
Rkpatt, that link doesn't seem to be working, can you try it again? It sent me to some cell phone forum |
I think I might have the idea. thanks.
now for questions... materials.. only steel or metal? what about wood or fiberglass(thick 1" or so)? just thinking about what I have to work with..wood working and fiberglass. what are you using to collect the oil? would it be possible to put rollers on the outside but below a collection setup..this would be using to stabliize the unit during an imbalance? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
dkenny, there is a fella on youtube that made one out of wood, the link is here:
wood centrifuge Its pretty neat, although it would scare the hell out of me to use For my centrifuge we built a lower bearing housing (just under the rotor) using 72 Chevy Malibu tapered wheel bearings (about $7 at the local checker auto parts store). They are such overkill for this setup that slight out of balance issues should be overcome. I have a container that surrounds the rotor and base of the centrifuge. Just for a quick use I cut a 55 gallon steel drum in half and used lexan (a lot like plexiglass) as a lid so I could see what was going on in the rotor. It works ok, but is leaky. Im building a new container and will post pics as it comes along. Steel is a readily available material and almost anyone with a cheap mig welder could build a unit like this. I would probably stick with steel for most situations. Our next one will likely be aluminum but I have a good TIG welder. |
How about any old steel wheel? They are already balanced to handle some level of high rpm: whatever a wheel hits at 80-90mph. Better yet; a drum brake. The shape is already about right. If you can get your hands on just the right model, it will have wheel stud pressed through it already and be moisture-tight. |
A drum can be difficult to weld on because they are cast. Its not like welding onto an engine block but it does make for some weak points (not a good quality in a centrifuge An steel wheel could work. at 90MPH it is rotating at about 1500RPM (thats assuming a standard size car or light truck tire of about 24"). A 15" rim would push some pretty high G's hooked up to a direct drive 1750RPM motor. The advantage would be the bearing housings would be readily available, just buy the spindle and bearing set for that wheel. The disadvantage would be having to make it liquid sealed. If the top lip were welded in the right place the wheel could still be put on a tire balancer and rebalanced after welding. Its a thought, and one my buddy Neil suggested it more than a few times. Although his idea was to buy a wheel blank (made of aluminum) with an extreme offset to make for a deeper bowl. It would save us some machine time on the new 'fuge'. |
It looks like I might a have project to make this fall winter. I've wanted a CF for a long time.
I was thinking about making a wood one.. I have a wood lathe so spinning to at 3600 is easy.. then fiberglass several layers on the outside. using the wood bowl mold.. make it made a little taller, maybe 10 inchs.. turn a pulley into the bottom.. run 6 wheel on the sides in 2 layers of 3. to help counter the force from the pulley.. not as safe as I would like, but what if 3 wheel( inline skate type) were mounted around the outside about 1/3 down from the top. oil collection would happen above this area.. -dkenny This message has been edited. Last edited by: dkenny, '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
I like the fiberglass reinforced wood idea, if that guy on youtube can use straight wood and not have it explode then fiberglass reinforced should work even better if applied correctly. The outside rotor wheels is a good idea as well to add stability and absorb a lot of the built up energy forced to the sides of the rotor, although I bet you won't need it for an application running these G's. |
how did you decide on the height of the rotor?
if all goes well I've on made from freon tank this weekend. I'm wondering if the tank is too tall. I mount the tank to the blade spindle from the large riding lawn mower. now I just need to build the box around it and figure out a motor/pulley setup..the spindle has a pulley on the other end from the blade. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
All home brew centrifuges need to be operated inside a substantial metal scatter shield (like steel drum, at least until proven absolutely safe and reliable. At the speeds a functional CF operates, any significant wobble or imbalance or weakness can turn your centrifuge into a grenade, shrapnel and all.
Excellent discussion, Please carry on. troy |
troy, point well taken..that's why I adding extra wheels at the top..just in case..
here is a useful link http://www.calctool.org/CALC/p...ewtonian/centrifugal -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
Neat calculator but it says my centrifugal force is 3380.71 G's?!?!
I used the old school paper and pen method and came up with 2000 (about that anyway) Might have to recheck my math |
I found it and was playing with it because the AC motors that i have are 1725..sure I can use pulleys to change the speed. I was wondering what the g's were using 1800 instead of 3600..
I need to work on my balancing..troy was right...mines not balanced and I haven't put the extra wheels on yet..I'm wonding if the tank is 'round'..if not I might have to make a wood one..atleast I can test this at high speed on the lathe..just playing with it a less than 1725..maybe 1200rpm..a guess because of pulley sizes..I had it spinning untili added 16oz of water..then it ran apart..not damage of injury. next time I have the off sw closer.. I wish the youtube wood lathe person would post details about the bowl..what wood? single chunk? laminated? -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
phooy...the tank isn't round enough..and would be too hard to make round.
but I did have an idea for the wood version..plywood..cabinet grade..these contain lots of thin layer already glued together..now I just need to glues several layers together. I thought about rotating each layer by 30 degrees from the last..something to work on.. more later -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD 99 dodge 2500 5.9l 24v..-mine everything run B100 when its warm enough |
Just remember, balance is ultra critical, these things will, repeat, will, grenade at centrifuge speeds, commercial centrifuges that have been balanced to near perfection still grenade now and then, so use extreme caution and don't let anything you don't want large pieces of shrapnel sticking out of near it.
