The milk tanks I've seen are all horizontal and have undesirable corners where unreacted oil could be trapped.
Also, the tanks I saw did not have tight sealing lids. www.MurphysMachines.Com The best Do-it-Yourself Construction Plans on the Internet! Waste Oil Heating - Biodiesel Systems |
Do you need to have tight sealing lids on the reactor?
My appleseed currently has 2 vent tubes that allow gasses to escape is why I am asking. The horizontal nature of the tanks are weird for sure, but the agitator in it is desirable, don't you think? |
If you don't want methanol vapors in your work space, YES. |
I don't believe the agitator in a milk tank would have the aggressive characteristics required for biodiesel mixing. While that doesn't mean it couldn't be used to compliment a pump mixer, there are other issues involved such as the design of the agitator mechanical system. One little spark in the wrong place and your milk tank might go sub-orbital. In-tank type mixing devices require special seals to prevent any chance of becoming an ignition source. I would strongly recommend against using a milk tank of that type. While I do recognize they are common and easy to come by, you'd be better off with a cheap 500 gallon propane tank like my MM500 plans use. www.MurphysMachines.Com The best Do-it-Yourself Construction Plans on the Internet! Waste Oil Heating - Biodiesel Systems |
We've used a 2000 gallon horizontal dairy tank for a couple of years now in our facility and it works really well. It has a horizontal agitator and 50% jacketed wall for heating. That may be a different type of dairy tank than what you're thinking, but it was a dairy tank. I think that they're right, if you get a square dairy tank, you'd need really good agitation to keep from getting stagnation in the corners. Just my 2cents.
-Dave Dave McCandlish President, Ohio Agrifuel B.S., ChE Ohio University |
