Hi All,
I've found an eductor for the Appleseed. I don't have the time or the ability to test it out extensively on my own. The eductor comes out of initial testing discussed in this thread. You will get an eductor with three different insert nozzles and an adapter pipe for mounting in an Appleseed. In exchange you will perform several tests. Warning, your biodiesel may not pass 3/27, so if every drop you make needs to meet 3/27, then this is not for you. You will run three tests. Test 1 and 2 need to be the same oil Test 1 is a control where you record specific information and run the 3/27 test at intervals during mixing. Test 2 is identical to test 1 except with the eductor installed. Test 3 is to see if you can make 3/27 passing biodiesel using the eductor and loading the methoxide as fast as you can. The eductor and adapter will be sent to you at no cost to you.
We have half of the people we need. Still looking for volunteers.
The initial tests look very promising, we just need to find out if those results can be consistently maintained with a variety of oil, operators, and installations. |
Only a few slots left folks.
Rick,
You got my email saying I'd like to test, right? |
Yep,
I need a "ship to" address and then you'll be officially part of the beta test. |
Welder,
The flow is from right to left. In our application the male threads are not used. The 1/2" npt female threads under the hex will be screwed onto a 1/2" pipe with one of the orifaces and compression ring installed between the eductor and the pipe. Minor leaks are not an issue since this is all inside the tank. To give some scale to the eductor, the threads on the left are 3/4" npt. The nozzle sizes are 1/8" 3/32" and 3/16" |
That's good news.
I just didn't want anyone to accidently damage their new eductor, that's all. |
Installation
The eductor has three major parts, The eductor it'self A 3/4" x 4" Adapter nipple A 1/2" x 12" pipe nipple It will be assembled like this, only when finished it will be inside the tank. I've placed the middle of the eductor at my 120L fill line.
In the above picture, I've removed the heating element. The eductor will be mounted on the 1/2" pipe and inserted through the upper element hole.
This will be fished up through a 3/4" port on top and the 3/4" adapter nipple attached to it. The ideal place is in the same hole it returns to originally. First Problem, I was using the cold water inlet to return my oil back into the water heater. It has a lip on it that holds the dip tube in place. This lip prevents me from sliding a 1/2" pipe through. I'll be moving my return line over to the annode rod hole. I'm using that for a vent now, so I have a little re-arranging to do. Once you have a hole you can fish some strong twine through the top hole and out the upper element hole. Run the twine through the pipe and eductor and tie a nut on the end. leave several feet of twine so you can pull it back out when your done.
After removing the vent from the water heater, pull the 1/2" pipe with the eductor up through the vent and attach the 3/4" adapter nipple.
Then put everything back together again.
From the installation pics, now I understand. There won't be any torque across the fins at all.
Hi Rick
In the pic .... .... you say ....
Should that be right to left? I was looking at ... ... and thought the eductor must be on upside-down, but I think it's just the left > right comment that needs changing. Or am I misunderstanding something else? Rover 75 + Skoda Fabia on B100 http://www.graham-laming.com Bicycle on G100 12,000 miles p.a. ( http://tinyurl.com/krppyc ) |
Graham,
Your correct. The flow is from right to left. I've changed it in the post above. |
I was thinking the same - that eductor IS upside-down surely? |
The nozzle fits inside the female threaded end and is held in place by the pipe threading into the eductor.
In the picture, the nozzle is on the left and the diffuser is on the right. The most important part of an eductor is the nozzle and will increase flow by a theoretical 3X. The diffuser (on the right) makes the eductor more efficient and brings the theoretical flow to 5X. When this batch cools down tomorrow, I'll see if I can make a short video of it in action. |
Ah! that last picture makes it clear - thanks Rick.
Hey Rick,
Are there any tester slots left? I'd like to give this thing a shot, as I had trouble with my static mixer, due to my use of a roller pump, instead of the HF pump. The static mixer created too much load on my pump, and stalled the motor. I'd like to know if this would do the same. Thanks! Brian ----------------------------------- Just purchased 2/1/08, 1985 F-250 2wd 6.9 IDI C6 Auto 186k $400 at auction. Was running my B100 in my fathers 1995 F250 PowerStroke, with >215,000 miles, on truck. So far, only about 500 on bio, but no problems yet. Lost my oil supply at the end of 2007, now gearing up to grow my own. |
Video of the eductor in action. This is unwashed biodiesel with the methanol removed. It has not had enough time to settle out the soap. It's a big 3.8Mb Widows Media file.
http://kitchen-biodiesel.com/eductor_video.htm |
What is a "roller pump"? We still have a few slots left open. |
| Powered by Eve Community | Page 1 2 3 4 5 6 7 8 |
