This works perfectly
Three filters is overkill, one 5µ is adequate on the output of the barrel pump. --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
Look into the Whale Gulper, I have a friend that pumps WVO and he likes the power it has.
I use one of these,
There are lots of used ones for sale out there. It works great but the bio is eating the stock filler hose on it... Jon This message has been edited. Last edited by: Jon Heron, |
ShurFlo series 2088 pumps. These come in either 115V or 12V.
I have 3 115V ones and a 12V one. The 12V one is dedicated to the tractor fueling station, and sits on top of the drum. The pump is always full of B100 and winters that way as well. 3rd year running without so much as a hickcup from it.Works flawlessly. We've run leads with alligator clips from the pump that attach to the tractor's battery for power and the braided hose has a ball valve on it to open and close flow. Simple,reliable,self priming,can run dry and mobile. You can see a picture of it here: http://www.b100wh.com/b100family.html It is at the bottom under all the tractor pics. HTH ![]() **My reactor/processor :B100WH.com ** Video of my system **The Colaborative Biodiesel Tutorial **B100 Heated Winter System ** Biodiesel Glycerine Soap - Make & sell soap from Biodiesel Glycerine |
Jon, I can't see your photo. I just see an x.
Legal Eagle, does your pump have enough pressure to pump thru a filter? Dave |
How about now?
Here are some more pictures of them HERE. I bought mine off of craigslist for $200.00CAD brand new in the box. Jon |
I use a modified Chevy oil pump. Made one for a friend from a Chrysler oil pump too. HTH
Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
The ShurFlo 2088 series pumps have a 45PSI flow rate. The one I use on the demething tank also pushes the biodiesel through a CAT 2 micron canister type fuel filter.No problems.
