Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Biodiesel Equipment    Speedy oil moisture tester (Personal Album)
Closed Album Closed
by Ant (created on )Gallery | Comments
A few pics Of the Ashworth Speedy Moisture tester findable from resellers with a google search at about $1000 or £700 new or on ebay every so often for less.
You want the one for oils but the main difference is that the oils one uses a syringe instead of a scale to measure the sample. If you find a secondhand soil one I can always pass on the calibration of the syringe for you to duplicate.
The size of the testing chamber also varies and the % moisture calibrated on the dial can also vary and go as high as 50%. That one is for testing concret aggregates.
Ashworth
Sycamore Avenue
Burnley
Lancs
BB12 6QR
England
Tel ++44 0282 39911
Telex 635520
Fax 38729
Can't vouch the numbers will be up to date this was taken from a manual written in the 1980's.
Ahworths invented and developed this method in the 1930's. They are still in business and seem to have an established global niche market. They make other equipment too.
This message has been edited. Last edited by: Ant,
The slideshow requires Flash Player 9.0.124 or higher.
Please click here to install it.
Closed Album Closed
