Sponsors    Home    Forums  Hop To Forum Categories  Biodiesel Equipment    Fill-Rite 800C Meter
Hello,
I put together a little filling station: 55 gallon drum and a used fill-rite 12V 15 gpm pump with a fill-rite 800C flow meter attached. The problem is the meter is not accurate and after following the instructions in the manual about calibrating, its still nowhere near close. Like I can get it to pump four gallons, but the meter reads 5. Thats 20% inaccurate.
Does anyone have actual experience with these and know how to remedy the problem?
Doug
Sorry I have no advice to fix it but I can tell you that they can work well.
I have the same one and it was accurate right out of the box. I havent checked it since I first installed it but I would notice if it had gone that much out of whack...
Maybe give the manufacturer a call?
Doug
-are you sure your not sucking air in prior to the meter, I know that air pumped when the tote is near empty will cause faulty readings. Tom
Have you tried running some diesel through it and seeing if its more accurate? It could due to the extra viscosity of bio. Or maybe it could be calibrated for gasoline?
Yes I was right, I just downloaded the user manual for it from tuthill here:
http://www.tuthill.com/admin/D...er_Owners_Manual.pdf
It says it was calibrated using mineral spirits (very thin) and will need to be re-calibrated for other fluids. There is a calibration screw inside and that owners manual shows how to do it.
Sounds very similar to the meter I had maybe 9 months ago.
Bio compatible, adjustment screw, etc. Bought it from a well know mail order place. I could not get it to calibrate, e.g. ran out of adjustment. It was about 20% error too. Manufacturer person could not give a satisfactory answer, other to possibly drill out the port a little bit to gain more adjustment (which would void warranty).
Sent it back, full refund came along with shipping charges covered.
Registered: 22 September 2005Reply With QuoteEdit or Delete MessageReport This Post
There are different kinds of errors that measuring equipment can exhibit. In your case, if it is always off by exactly 21% (as an example), you can just print up a little conversion chart. Read the indicated number, look that up on the chart and translate that into the real number.
On the other hand, if it's off by 21% when the fuel is 70F, and 28% when the fuel is 42F, or just randomly off by 10-34%, then you're beat.
HTH,
troy
Do you guys put a check valve in place after the meter? The manual makes some reference to this. I do get surges in the pump and there is no auto shut off on the dispenser handle (open to the air.) Perhaps that is what is causing this problem?
Doug
