Sometimes on car shows where they spray paint the car with a custom paint mix, you see the painter pour the paint from the can, through a fine media filter, into the spray can.
What is the micron rating of this media?
Masochist to Sadist: "Hurt me." Sadist to Masochist: "No."
The ones Dad uses don't have a rating written on them, but I would say by looking at them they have to be over 50 micron. Don't know if they come in different sizes or not.
Location: Southington, OH | Registered: 24 January 2003
i run a fuel truck and dispense fuel into trucks one by one the filters i use are from oil equip. companies they are about 100.00 dollars apiece but they lastfor over 50000 gallons of dino but what im looking for is away to strain and use and refine used car oil as a percent of dino diesel used along with my recycled veg can this be done? someone asked earlier about buying oil verses collecting birmingham hide and tallow would sell but only in bulk my advice is that you can buy a tote tank used for about 100.00 dollars and set out offer 75.00 each time its filled up and create someone a job youll find someone who will hustle and eadn up with 3or4 a week
Location: anniston alabama | Registered: 30 December 2005
I made a filter out of three rolls toliet paper w/ cores removed. Put a pipe w/holes drilled down through center of rolls then put this down inside of larger pipe. Then I pour waste motor oil down center tube and collect it w/ tire valve outlet. I burn it in my one cylinder petter diesel.
