Biodiesel & SVO Home
Biodiesel & SVO Forums
Conservation & Efficiency
can i use a generator to feedback to the power grid?
Topic Closed|
It can be done, but it isn't that simple.
Do a archive search on cogeneration, and "motor as a generator" Eric |
If you are intending to use 120V or more it's really not worth messing about. The dangers of getting it wrong are too high and there's a good chance you'll blow equipment connected to the "faulty" generator. Standby generators are not cheap for good reason.
The problem with using an induction motor is freqency control. If it's grid connected the grid will fix the prequency. But off grid, I dont think they are much use. There are all sorts of other issues I wont try to bore you with, but basically dont bother. You really need either a d.c. generator and an electronic a.c. converter or a regulated a.c. generator. If you have a battery pack with a.c. converter and a generator, you need to make sure that one or both can sychronise the frequency and phase before connecting. Just throw the switch between unsychronised generators and you'll have an expensive bang. |
Topic Closed
