They're still working on it. The automotive microprocessor folks (like Motorola) are actually pushing it pretty hard because it means they'll sell LOTS of fast expensive processors.
Eric
| Location: Saginaw, MI, USA | Registered: 30 January 2002 |   |
Well, I work at the largest valve supplier in the world, so I can say with confidence. Not a lot, but it's coming along. The problems are that you need a LOT of energy to open valves at that frequency, so you need a big solenoid at 12V, or a smaller solenoid at 42V. The current direction is towards 42V systems. There's a lot more development here in variable valve timing, and deactivation.
fly-by-wire valve gear. Sounds like a catastrophe waiting to happen. I suppose that when the valve timing goes all to cock and the pistons meet the valves (as when a timing belt snaps  ) then the manufactures will be able to quote Kim Stanley Robinson and say it was "something in the silicon" regards dva
| Location: Yorks,England | Registered: 30 June 2001 |   |
I heard a while (year?) ago that BMW has an engine without a throtle butterfly plate. Uses variable valve timing exclusively to regulate intake volumes. Don't know if it was electric...?
| Location: Rochester, NY USA | Registered: 27 February 2003 |   |
