Biodiesel & SVO Home
Biodiesel & SVO Forums
Conservation & Efficiency
An actual tiny 4 inch by 12 inch turbojet engine
Topic Closed|
member 2008 Sponsor |
Just happened to run across this web page, says it is somehow associated with nasa. A very good technical discription of this engine along with data. Uses an existing turbo compressor but the engine is an in-line unit, dosen't use the normal turbo housing
http://www.allstar.fiu.edu/aero/tinyturbo1.html (here) --------------------------------------------------------------------- 92 dodge cummins with over 260,000 miles. Running an unheated 50% diesel/50% WVO blend for about the last 75,000 miles when temps above 50 deg f, no modifications or heating except the addition of a throw-away in-line fuel filter (removed during cold weather). As of 8-01-05 I have been testing a 75% WVO/15% gasahol (90% RUG/10% ethanol)/10% diesel blend. Works fine down to about 65 f then starts rough. Runs ok once engine warms up. Back to a 50/50 diesel blend sence 9-15-05, just to cool now. -- 11-01-05 Modified stock fuel tank internal fuel pickup to have I.D. of 3/8 inch, this eliminated cold start slow idle and bogg on acceleration. Now adding 1 ounce each of acetone and pure gum spirits of turpentine to each 5 gallons of any blend, seems to help keep the fats in solution to a lower temperature --Heated 2nd tank in the works |
Topic Closed
