is it O.k. to convert the d50 to svo I am thinking of getting a 1986 4x4 and I haven`t done a conversion before
Look for a Toyota head, they're the same, but equally as rare, also the 86 block fits the same specs.
I'd like to think so but the engine is very very sensitive. I now have an '86 block in an 83 that runs very well but at the first instance of water clams up and I'm still not sure what the issue is. But with 3k on a brand new rebuild I'm dealing with a knock that's either a bearing or injection failure and threatens to throw a rod. I'll post my symptoms in a new topic. Save your oil - Fuel the planet Dodge TD50 2.3L '83 HP injectors SVO; D#2/BIO mix main tank Greasecar 2 tank heated filters/ Racor HE/ dual FPHE (31plates total) Fattywagon customized extra long single heater (15A) relayed on toggle. 120 gal saddle WVO fuel tank settling filtration. Graco blue devil transfer pump DC OC20 80psi PS pump 1/4hp 1725rpm Westinghouse motor |
Doing a search for this engine head, i came up with the following link. http://www.automotix.net/20070706-used-mitsubishi-parts.html http://www.headsonly.com/mitsubishi.htm Randy H. |
hi I have a1983 D50 4x4 i live in loreto baja california .Im having trouble finding the oil air and diesel filters could you help mike
