No incentive to try a brake servo vac pump then?
| Location: Manchester UK | Registered: 03 June 2003 |    |
member 2008 Sponsor
Tim; I've just gone through some copy/post collection I did on this project and I have a question. By the way we started building our furnace today using tilling disks from the early 1900's and an old water heater that leaked. Anyway, my question: I understand that the oil feed follows the air intake down to the edge (5" above the upper bowl surface)and then drips into the upper bowl, but how does the oil get to the lower bowl ?
| Location: :-) Great White North eh ? | Registered: 10 December 2004 |    |
Hey Legal go to page 2 of this post... Small trough with calibrated? hole to drip down to next bowl... I worked on my stove today as well, but i took the high road all new materials willpost some picts tomorrow... Tigman
just a WVO freak and lovin it..
| Location: simms montana | Registered: 02 August 2005 |    |
I also noted that tim went to a larger are tranfer tube between the bowls!! i am going to swedge a 2" piece of stainless pipe into a funnel shape to hopefully increase the air speed to the lower bowl!! I will have no base test for this so I guess that will be my base.. Tigman
member 2008 Sponsor
Pump -- Still looking for the perfect pump, but this will do for now.
Tilling disks -- I have used an 18 inch one of these for the base on my other syphon style gun burner unit, these disks are HARD - don't even try drilling through one, even after heating the area red hot a couple of times, I finally heated the area where I needed the hole to a red heat and used several tapered punches to punch the holes, then ground away the funnel shaped excess metal, red heated again and banged into shape. I used an angle gringer to cut out the large 5 inch diameter hole for the burner unit, that worked OK. These are also difficcult to weld things to, due to the high carbon content of the disk alloy the weld has a tendancy to crack away from the base metal unless you use a "low hydrogen" rod, I used 7018 stick welding rod successfully.
Lower bowl fuel feed -- Yep, leaky fuel shoot sticks up at about a 30 degree angle out over the opening of the air tube passageway.
Larger diameter air passage tube -- This is all still in testing, the larger diameter seems to be working fine, only thing I notice different is that the fire does not "roar" as loud as it did but this may also have something to do with the new 3 1/2 inch distance between the bowls now ? let us know how your tapered passage works.
| Location: fisher,illinois,usa | Registered: 03 June 2003 |    |
a gee dub clone!!!! burner chamber w air intake.. Tigman
better angle pict... Tigman
Wish you two had workshops next to mine...
I'd just put ya to work cutting tiny pieces, then putting them back together...LOL Tigman
took a few minutes to tack base of burn chamber on and work on burner stand, lower burner in place removeable, it's a sin but i had a beer in my hand and poured some in burner to see puddle pretty even puddle... Tigman
another shot
last one for tonight gotta go!!
got a little time today to tinker here's some more photos Tigman
another
yep another
last one
member 2008 Sponsor
Feaking SWEET !!!!!!!!! Arc Welding?? Doesnt look like mig..
