Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Biodiesel For Heating    beckett line heater
beckett line heater
Right before Christmas, I ordered a Beckett "start helper kit" it is basically a line heater that goes onto the metal line just behind the nozzle. it is super simple to hook up. you just wire it into the incoming 120v lines, and forget about it. I decided to give this a try because for whatever reason, I was having two no-lights a day running B100. Now this started happening after running successfully for 2 years on b100. I tried all the usual things, nozzle, adjustments, etc. so I gave the start aid a try, and so far so good. I've not had to go down stairs once. I'll keep everyone updated as the winter goes on. but for 29 bucks, so far it is money well spent. I got it at patriot supply.com hope this helps anyone having trouble.
powering
2 bobcats, an excavator, and a ventrac mower. looking for a diesel weedeater!
Location: morgantown wv | Registered: June 18, 2008Reply With QuoteReport This Post
i been blending 30% vo with 70 d2 and running with no problems for a year, wonder if i install one of those and preheat my fuel if i can get away with 50/50 mix. might have to look for one and start experimenting.
Registered: October 01, 2009Reply With QuoteReport This Post
this thing was stupidly easy to install. it took me longer to open the box and get my tools. I don't have any experience with burning vo, so I can't help much there. I would say it has to help. It doesn't likely get too hot, parts of it are plastic.
powering
could you get me a part number? id like to try one too, ecpecialy if it's stupid easy to install lol
thanks.
51621 starter helper kit. I got it from patriot supply .com
powering
thanks, i think i might give one a try and fool around with some higher blends. i like the idea of bd but i havn't come up with a good way to get clear of the glycerin. havn't really poured my heart into it yet tho, i'm more of a svo guy so far.
that is a common problem. I've been making soap, both bar and liquid. but I could never make enough to use up what I generate. right now most of mine is getting composted, and the jury is still out on that, having just started.
powering
i like the idea of making a boiler that i could burn them wood chip and glycerin logs they make that i could heat a big hot tub and have wild parties in,,,,ways off though, i'l post pics if i ever have one.
Yeah by all means do that.
I'd love to see some pics of a wild hot tub party!
Big Grin
hahaha i got to get my priorities in order and get workin on that
