water tank... oil in it?? Im certainly no expert. but makes no since to me that their would be any way for fuel.... rather it be kero, diesel, or Veg. to get into the water tank. They should not have any connection.
Is this a boiler for heating or a hot water heater? What make is the burner unit? did you replace seals, Orings etc. with viton ones or check in advance if it already had some? Did you ensure your B50 had no left over methanol in it? This would eat seals faster than B50 alone. Even with bad seals though... can't see any connection with fuel being in the water tank. _________________________ If you believe you can't YOUR RIGHT; But equally so.... if you believe you can, YOUR RIGHT as well. |
What do you mean by "oil heater"? Be more specific.
--.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
Leo
-when you switch from heating oil to b50 or 100, you have to increase the fuel pressure. if you put the next size smaller nozzel,and chock off the combustion air, it really helps with the ingnition. How many times did you try to start it? and was it realy pumping any oil (it didn't light) remove the burner, and check inside the fire pot. if it is wet with oil, sop it up with lots of paper towel. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
He is correct I have been a victim of this when I was servicing oil burners. You should only push the reset button once maybe twice. An old service man taught me if you get a spray bottle and mix some Joy liquid soap and water in it and spay it in the chamber use a lot this will slow down the burning of the un-burnt oil in the bottom of the chamber. If is started with out ding some thing once the oil catches on fire it may back draft or it may only sound like a jet engine.
andyn
-or it may blow you on your as s -sop up the extra fuel for sure!!! Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
Now that makes perfect sense. Oil in the bottom of the burn chamber. The orginal poster said oil in the bottom of the water tank.
I have a fuel oil furnace with a Beckett AFG burner. I never thought there was the chance of an exposion with fuel oil or biodiesel ,but I found out the hard way. I did have an explosion and it made me respect the hazards of un burnt fuel oil. It wasn,t usual rumble type. A serviceman said the unburnt fuel on the bottom of the pot can release vapors and make conditions ideal for an explosion. Don't use the reset to many times. I still need to get my furnace checked because I wonder if the firebox split.
Ohhh so I'm not alone
